Here’s some code. Completely untested but based on what @Gunner has mentioned.
(I know it could be condensed a lot but it’s just an example)
You should be able to use it as a base to get you going:
int iState = 0;
BLYNK_WRITE(Vx){
String tInput = param.asStr();
switch (iState){
case 0:
terminal.println("Main menu");
terminal.println("Type CC to change WiFi credentials");
terminal.flush();
iState = 1;
break;
case 1:
if (tInput == "CC"){
iState = 2;
} else if (tInput == "Exit"){
iState = 0;
break;
case 2:
terminal.println("Current credentials:");
terminal.print("SSID: ");
terminal.println(ssid);
terminal.print("Pass: ");
terminal.println(pass);
terminal.println("");
terminal.println("Change details?");
terminal.println("Type Y or N");
terminal.flush();
iState = 3;
break;
case 3:
if (tInput == "Y"){
iState = 4;
} else if (tInput == "N"){
iState = 0;
break;
case 4:
terminal.println("Enter new SSID");
terminal.flush();
iState = 5;
break;
case 5:
ssid = tInput;
terminal.println("Enter new pass");
terminal.flush();
iState = 6;
break;
case 6:
pass = tInput;
terminal.println("You entered:");
terminal.println("Save or change details?");
terminal.println("Type S or C");
terminal.flush();
iState = 7;
break;
case 7:
if (tInput == "S"){
iState = 8;
} else if (tInput == "C"){
iState = 4;
break;
case 8:
terminal.println("Credentials saved.");
terminal.flush();
iState = 0;
break;
