Good Morning. In Blynk Iot, the Terminal Settings widget does not show the last text. Every time you open the APP, it is empty. Only when the hardware sends an update to the Blynk cloud does it appear. What should I do so that when the App is opened it already shows the information that is in the cloud?
Recording is not implemented
how do i implement recording?
You can’t !
It is not implemented with Blynk 2.0
Thank you for your help. Blynk legacy was better
@Andre_Carvalho you should search before creating posts like this. This issue has been discussed many times, along with possible alternatives or workarounds. You just need to search.
