Terminal connection
I hope I can explain my problem, because my english is not so good.
I have a sketch on an esp8266, which will controll my shutters (https://github.com/zwiebert/tronferno-mcu). For this I had to send a string like this “g=1 m=1c=up” via terminal to the esp8266. How can I do this with blynk.
Thanks Grave
Personally, I’d go for MQTT, possibly using microMQTT.
You could then use an ESP8266 or ESP32 as a Blynk to MQTT Bridge.
