Itâs much easier if you post your serial output as test rather than a screenshot. Highlight the text in the serial monitor using the mouse (or CTRL A to select all) and copy using CTRL C. Paste it into your post in the same way as youâd post code, with backticks and cpp.
I assume youâre saying that the requested data is in the wrong format because itâs showing âC: 20.00 F 68:00â and you were just expecting â20.00â?
The serial monitor output is coming from the myTimerEvent
function which is being called every second. This in turn calls the printTemperature
function (the last 20 or so lines of code in your sketch), and this is where the formatting that youâre seeing is coming fromâŚ
Serial.print("C: ");
Serial.print(temperatureC);
Serial.print(" F: ");
Serial.print(DallasTemperature::toFahrenheit(temperatureC));
earlier in this printTemperature
function, a local variable is being declared called âtemperatureCâ âŚ
float temperatureC = DS18B20.getTempC(deviceAddress);
Itâs local to this function, because itâs being declared here rather than at the top of the code. This means that the temperature readings that youâre taking every second are simply being thrown away and not used at all in the rest of the code, so this data is irrelevant anyway.
Youâre taking another temperature reading in the getSendData
function and assigning this to the global variable âtempâ.
temp = DS18B20.getTempCByIndex(0);
Youâre using a different method to get thuis data from the probe (getTempCByIndex as opposed to getTempC(deviceAddress). Iâm not familiar with the probe and library that youâre using, so I donât know the difference between these tow library function calls, but the code used in the printTemperature
function seems more robust, as it does some error checking for readings of -127.00 degrees and rejects them if they occur.
I also noticed that the syntax of your if statements in the Heater
and Cooler
functions was incorrectâŚ
void Heater() {
if (temp < desiredTemp - tempDiff ); {
This has a semicolon after the if condition, which will stop it working correctly. It should be:
void Heater() {
if (temp < desiredTemp - tempDiff ){
Your second if statement within the function was missing an opening curly bracket. This means that the logic of these functions was totally screwed-up and wouldnât give the expected results.
Iâve changed your code as follows:
We now take a temperature reading every 1 second and assign the result to a global variable. removed all the fancy formatting and Fahrenheit reading, simply print the results.
Removed the temperature reading code from the âgetSendDataâ function and just used this to send the data to Blynk.
Sorted-out the if statements to remove unwanted semicolons and add-in the missing curly brackets. Also chnaged the positioning of the curly brackets (purely cosmetic) to help with debugging
Added some more meaningful serial.print statements so you can track the program flow
Renamed your functions to describe what they actually do.
A couple of other thingsâŚ
Your comment says V10, but itâs actually sending the data to V5
And finally, itâs not a good idea to share your Blynk Auth code to a public forum. It would be very easy to use this to write strange data to the Blynk server. For example, I could write a value of 100 to pin V11 with a simple API call. This would set your target temperature to 100 degrees centigrade!. Once you have the code working as you want, use the app to refresh the Auth code and update your sketch with the new code that is generatedâŚ
Hereâs the amended code. It compiles, but I donât have the hardware to check if it actually works. Read through my comments above so that you understand what changes Iâve made and why.
DS18B20multiple.ino https://community.blynk.cc/t/arduino-mega-2650-with-w5100-multiple-ds18b20/16706/10
YourDuino Multiple DS18B20 Temperature Sensors on 1 wire
Connections:
DS18B20 Pinout (Left to Right, pins down, flat side toward you)
- Left = Ground
- Center = Signal (Pin 2): (with 3.3K to 4.7K resistor to +5 or 3.3 )
- Right = +5 or +3.3 V
Questions: terry@yourduino.com
V1.01 01/17/2013 ...based on examples from Rik Kretzinger
/*-----( Import needed libraries )-----*/
#include <Ethernet.h>
#include <BlynkSimpleEthernet.h> // This part is for Ethernet stuff
#define W5100_CS 10
#define SDCARD_CS 4
char auth[] = "d27bf6f0a098498a81a5c65dab79b851"; // Put your Auth Token here.
int Vpin = 5; // will use Virtual pins 5, 6 and 7 for Sensor data
#include <OneWire.h> // Get 1-wire Library here: http://www.pjrc.com/teensy/td_libs_OneWire.html
//Get DallasTemperature Library here: http://milesburton.com/Main_Page?title=Dallas_Temperature_Control_Library
/*-----( Declare Constants and Pin Numbers )-----*/
#define ONE_WIRE_BUS 48// DS18B20 on arduino pin2 corresponds to D4 on physical board
DallasTemperature DS18B20(&oneWire);
/*-----( Declare Variables )-----*/
// Assign the addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
DeviceAddress Probe01 = { 0x28, 0xFF, 0x2D, 0x5A, 0xC4, 0x17, 0x05, 0xEF };
float temp;
int relayPin = 49;
int relay2Pin = 28;
float desiredTemp = 26;// set this to your desired temp
float tempDiff = 1;// this variable provides a small +/- temp differential that will prevent constant relay switching.
BLYNK_WRITE(V11) // Triggered when the value of V11 in thye app changes
//reads the setppoint
desiredTemp = param.asFloat();
BLYNK_WRITE(V12)// Triggered when the value of V11 in thye app changes
//reads the differential
tempDiff = param.asFloat();
void send_data_to_blynk()
// DS18B20.requestTemperatures();
// temp = DS18B20.getTempCByIndex(0);
// Serial.println(temp);
Blynk.virtualWrite(5, temp); //virtual pin V5
Serial.println("Data sent to Blynk");
}//--(end send_data_to_blynk )---
void Heater()
digitalWrite(relayPin, HIGH);
Serial.println("Heater function where temp < desiredTemp - tempDiff");
Serial.print("temp = ");
Serial.print("desiredTemp = ");
Serial.println(desiredTemp);
Serial.print("tempDiff = ");
Serial.println(tempDiff);
Serial.println();
if (temp > desiredTemp )
digitalWrite(relayPin, LOW);
Serial.println("Heater function where temp > desiredTemp");
Serial.println();
}//--(end Heater )---
void Cooler()
if (temp > desiredTemp - tempDiff )
digitalWrite(relay2Pin, HIGH);
Serial.println("Cooler function where temp > desiredTemp - tempDiff");
Serial.println();
if (temp < desiredTemp )
digitalWrite(relay2Pin, LOW);
Serial.println("temp < desiredTemp");
Serial.println();
}//--(end Cooler )---
void setup() /****** SETUP: RUNS ONCE ******/
Serial.begin(9600); // start serial port to show results
Serial.print("Initializing Temperature Control Library Version ");
Serial.println(DALLASTEMPLIBVERSION);
DS18B20.begin(); // Initialize the Temperature measurement library
// set the resolution to 10 bit (Can be 9 to 12 bits .. lower is faster)
DS18B20.setResolution(Probe01, 10);
pinMode(relayPin, OUTPUT);
pinMode(relay2Pin, OUTPUT);
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth); // Here your Arduino connects to the Blynk Cloud.
timer.setInterval(1000L, take_temp_readings); // Setup a function to be called every second
timer.setInterval(5000L, send_data_to_blynk);
timer.setInterval(1500L, Heater);
timer.setInterval(1300L, Cooler);
}//--(end setup )---
void loop() /****** LOOP: RUNS CONSTANTLY ******/
}//--(end main loop )---
void take_temp_readings()
//Serial.print("Number of Devices found on bus = ");
//Serial.println(DS18B20.getDeviceCount());
//Serial.print("Getting temperatures... ");
//Serial.println();
DS18B20.requestTemperatures(); // Command all devices on bus to read temperature
temp = DS18B20.getTempC(Probe01); // PK Comment - I assume that this is the correct way to get the temperature, if not then try "temp = DS18B20.getTempCByIndex(0);"
if (temp == -127.00)
Serial.print("Error getting temperature ");
Serial.print(temp);
}//--(end take_temp_readings )---
//*********( THE END )***********
thank you so much for your help iv now managed to get it up and running :). iv since added alarms and cutoffs to prevent overheating.
Excellent!
Hopefully youâve learnt something along the way as well.
Iâll change this to âSolvedâ.
i sure did thank you :). im now trying to sort out my next addition to my project but hving issues creating a variable timer with a slide input. the plan was to be able to change the dely of a relay cycling between on and off.
you have to use a timer for cycling relay.
you can start and stop it and change the delay as you want.
