looking for some pointers with my sketch. im trying to switch 2 relays. one for a heater and one fora fan. i wish to set the temperature and set a differance so if the temperature cooler than the temp-differance the heater will come on and the reverse for the cooling.
i have temperature readout on the app but im not getting any relays switching when they should. i have spent a fair few hours trying to figure this out now with now sucess so some pointers would be greatly apriciated.
thanks in advance
Adam.
``cpp
BLYNK_WRITE(V11){
//reads the setppoint
SetPoint = param.asFloat();
BLYNK_WRITE(V12){
//reads the differential
Differential = param.asFloat();
From the snippet of code that you’ve posted it’s almost impossible to tell what the issue is.
Post your full code, along with details of the hardware you’re using, how you’ve wired your relays, whether the relays are active high or low, etc. etc.
im using a mega with ethernet. one relay is a ssr the other is a sainsmart 16ch. i can switch the relays using a button in the app but my sketch wont control them
DS18B20multiple.ino https://community.blynk.cc/t/arduino-mega-2650-with-w5100-multiple-ds18b20/16706/10
YourDuino Multiple DS18B20 Temperature Sensors on 1 wire
Connections:
DS18B20 Pinout (Left to Right, pins down, flat side toward you)
- Left = Ground
- Center = Signal (Pin 2): (with 3.3K to 4.7K resistor to +5 or 3.3 )
- Right = +5 or +3.3 V
Questions: terry@yourduino.com
V1.01 01/17/2013 ...based on examples from Rik Kretzinger
/*-----( Import needed libraries )-----*/
#include <Ethernet.h>
#include <BlynkSimpleEthernet.h> // This part is for Ethernet stuff
#define W5100_CS 10
#define SDCARD_CS 4
char auth[] = "d27bf6f0a098498a81a5c65dab79b851"; // Put your Auth Token here.
int Vpin = 5; // will use Virtual pins 5, 6 and 7 for Sensor data
#include <OneWire.h> // Get 1-wire Library here: http://www.pjrc.com/teensy/td_libs_OneWire.html
//Get DallasTemperature Library here: http://milesburton.com/Main_Page?title=Dallas_Temperature_Control_Library
/*-----( Declare Constants and Pin Numbers )-----*/
#define ONE_WIRE_BUS 48// DS18B20 on arduino pin2 corresponds to D4 on physical board
DallasTemperature DS18B20(&oneWire);
/*-----( Declare Variables )-----*/
// Assign the addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
DeviceAddress Probe01 = { 0x28, 0xFF, 0x2D, 0x5A, 0xC4, 0x17, 0x05, 0xEF };
float temp;
int relayPin = 49;
int relay2Pin = 28;
int desiredTemp = 0;// set this to your desired temp
int tempDiff = 1;// this variable provides a small +/- temp differential that will prevent constant relay switching.
Send Sensor data to Blynk
BLYNK_WRITE(V11){
desiredTemp = param.asFloat();
BLYNK_WRITE(V12){
tempDiff = param.asFloat();
void getSendData()
DS18B20.requestTemperatures();
temp = DS18B20.getTempCByIndex(0);
Serial.println(temp);
Blynk.virtualWrite(5, temp); //virtual pin V10
temp = DS18B20.getTempCByIndex(1);
Blynk.virtualWrite(11, temp); //virtual pin V11
temp = DS18B20.getTempCByIndex(2);
Blynk.virtualWrite(12, temp); //virtual pin V12
void Heater() {
if (temp <= desiredTemp - tempDiff ); {
digitalWrite(relayPin, HIGH);
if (temp >= desiredTemp );
digitalWrite(relayPin, LOW);
void Cooler() {
if (temp >= desiredTemp - tempDiff );{
digitalWrite(relay2Pin, HIGH);
if (temp <=desiredTemp );
digitalWrite(relay2Pin, LOW);
void setup() /****** SETUP: RUNS ONCE ******/
Serial.begin(9600); // start serial port to show results
Serial.print("Initializing Temperature Control Library Version ");
Serial.println(DALLASTEMPLIBVERSION);
DS18B20.begin(); // Initialize the Temperature measurement library
// set the resolution to 10 bit (Can be 9 to 12 bits .. lower is faster)
DS18B20.setResolution(Probe01, 10);
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth); // Here your Arduino connects to the Blynk Cloud.
timer.setInterval(1000L, myTimerEvent); // Setup a function to be called every second
}//--(end setup )---
void loop() /****** LOOP: RUNS CONSTANTLY ******/
}//--(end main loop )---
void myTimerEvent() {
Serial.print("Number of Devices found on bus = ");
Serial.println(DS18B20.getDeviceCount());
Serial.print("Getting temperatures... ");
Serial.println();
DS18B20.requestTemperatures(); // Command all devices on bus to read temperature
Serial.print("Probe 01 temperature is: ");
printTemperature(Probe01);
Serial.println();
/*-----( Declare User-written Functions )-----*/
void printTemperature(DeviceAddress deviceAddress)
float tempC = DS18B20.getTempC(deviceAddress);
if (tempC == -127.00)
Serial.print("Error getting temperature ");
Serial.print("C: ");
Serial.print(tempC);
Serial.print(" F: ");
Serial.print(DallasTemperature::toFahrenheit(tempC));
Blynk.virtualWrite(Vpin, tempC);
}// End printTemperature
//*********( THE END )***********
help pete and thankyou for your replay. iv made the change but still not woking :(. strangely the cooling relay turns on when i pwoer the arduino before it has connected to the server.
The way it is, should work ish, however I believe you copied the example from somewhere as you’re measuring several probes via DS18B20.getTempCByIndex(0); and assigning to the same variable temp it would cause problems down the line.
my serial monitor shows my temperature perfevtly fine. strangely my numerical inputs for the setpoint and differance get changed to-127
Connections:
- Left = Ground
#define W5100_CS 10
#define SDCARD_CS 4
float temp;
int relayPin = 49;
int relay2Pin = 28;
int desiredTemp = 26;// set this to your desired temp
BLYNK_WRITE(V11){
BLYNK_WRITE(V12){
void getSendData()
void Heater() {
void Cooler() {
pinMode(relayPin, OUTPUT);
pinMode(relay2Pin, OUTPUT);
timer.setInterval(5000L, getSendData);
timer.setInterval(1500L, Heater);
timer.setInterval(1300L, Cooler);
Serial.println();
Serial.println();
What sort of output are you getting from your serial monitor?
I’d add some extra serial.print statements in your void Heater and Cooler functions that print the values of temp, desiredTemp and tempDiff so that you can see what’s happening.
I was hoping that the arduino would use those values should blynk disconnect so I don’t overheat or anything and I keep a stable temperature, I’ll remove the valves .
Connections:
- Left = Ground
#define W5100_CS 10
#define SDCARD_CS 4
float temp;
int relayPin = 49;
int relay2Pin = 28;
float desiredTemp = 26;// set this to your desired temp
float tempDiff = 1;// this variable provides a small +/- temp differential that will prevent constant relay switching.
BLYNK_WRITE(V11){
BLYNK_WRITE(V12){
void getSendData()
void Heater() {
if (temp < desiredTemp - tempDiff ); {
Serial.print(desiredTemp);
Serial.println(tempDiff);
if (temp > desiredTemp );
void Cooler() {
if (temp > desiredTemp - tempDiff );{
if (temp < desiredTemp );
Serial.println();
Serial.println();
float temperatureC = DS18B20.getTempC(deviceAddress);
if (temperatureC == -127.00)
Serial.print(temperatureC);
Serial.print(DallasTemperature::toFahrenheit(temperatureC));
iv added in some serialprints to help see what is going on in the monitor relay2 now says on but i think that may be because it might work in reverse being a sainsmart. But relay (my ssr0) flashes on and off. also in the serial monitor, it shows the requested data in the wrong format.
