Tabs BUG Blynk 2.0
I had three tabs in Tabs - I deleted the 2nd blank but I lost everything that was in the active 1st: (((… … is there a restoration from the backup ?!
IOS / Programm PLUS
I’m guessing that you hit the Delete button then confirmed with “Delete Widget ?”…
I can’t replicate the problem using iOS 3.2.1(0)
If you have a way of replicating it every time then I’d suggest that you raise an issue here:
and use the Send Logs option as well.
Some more info on tabs. You can delete individual tabs after you have two or more. If you have just two you obviously have to remove the widget.
