Table widget - how to check wich rows is selected
Hello guys,
please tell me how I can to check wich rows is selected in table. I needs to select more than one row at a time in the app and I need information wich rows is selected. For example :
If(rows1 == "selected")
rows_1 = 1;
@andrzej.pawlak please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
If you take a look at the Table widget documentation:
You’ll see that when a row changes and fires the BLYNK_WRITE(vPin) callback it returns “select” or “deselect” as param[0].asStr() and the row ID as param[1].asInt()
I don’t think that there any way to query the status of a row and I’m not sure what Blynk.syncVirtual(vPin) will return for a table, so it’s probably a case of you keeping track of each row’s status in an array.
