Tab widget - annoying feature or bug?
hello!
i’m not sure if it is intended or not, but on my active running project if i click twice on the same tab, it opens the tab widget settings window.
for me it seems a bug, because obviously i do not want to edit my tabs at runtime if i accidently double click them. it would be better to edit tabs settings only when the project is stopped, like with all other widgets.
thanks!
Thanks for reporting. Already fixed. Will be available in next update.
Hello Dmitriy,
I thought that you have programmed this behavior. Nonetheless I like it…
Correct. But only in edit mode.
