Hello people.
I have a problem with the program below.
The sistem is to know whether a particular POS materials of Coca-Cola is being effective or not.
The sensor in ledPin1 is to have flow of people, and others, it is to know whether or not interaction.
The taxaConv variable is to define the relationship between the number of people who have passed in front of the POS and how they interacted with.
I have two problems:
(1) when I try to know the taxConv I have instability in the system and the system does not respond with decimals and the result is passed only with integers;
(2) I do not have a high speed in the flow sensor and thus, lose accuracy;
I appreciate if someone can help me.
There is some suggestion of you?
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
You need to install this for ESP8266 development:
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
char auth[] = "my code";
WidgetLED led1(V7);
WidgetLED led2(V8);
WidgetLED led3(V9);
WidgetLED led4(V10);
int interacao_pir = 0;
int ledPin1 = D5;
int ledPin2 = 4; // Não funciona com o "D" na frente.
int ledPin3 = D7; // Só funciona com "D" na frente.
int ledPin4 = D6;
int buttonPushCounter1 = 0;
int buttonState1 = 0;
int lastButtonState1 = 0;
int buttonPushCounter2 = 0;
int buttonState2 = 0;
int lastButtonState2 = 0;
int buttonPushCounter3 = 0;
int buttonState3 = 0;
int lastButtonState3 = 0;
int buttonPushCounter4 = 0;
int buttonState4 = 0;
int lastButtonState4 = 0;
int buttonresetState = 0;
int lastButtonresetState = 0;
// Instancia timer
// Setup
pinMode(ledPin1, INPUT);
pinMode(ledPin2, INPUT);
pinMode(ledPin3, INPUT);
pinMode(ledPin4, INPUT);
// Blynk.begin(auth, XXXX);
Blynk.connect();
// Wait until connected
timer.setInterval(100L, pir1);
// timer.setInterval(1000L, pir2);
// timer.setInterval(1000L, pir3);
// timer.setInterval(1000L, pir4);
//timer.setInterval(10000L, conv);
void sendUptime()
Blynk.virtualWrite(V0, millis() / 1000);
Blynk.virtualWrite(V5, (interacao_pir = buttonPushCounter2+buttonPushCounter3+buttonPushCounter4));
Serial.println(interacao_pir);
void pir1() {
//while (buttonresetState == LOW){
// read the pushbutton input pin:
buttonState1 = pulseIn(ledPin1,LOW);
// Serial.print("Tempo = ");
// Serial.println(buttonState1);//}
// compare the buttonState to its previous state
if (buttonState1 != lastButtonState1) {
// if the state has changed, increment the counter
if (buttonState1 != 0) {
// if the current state is HIGH then the button
// wend from off to on:
buttonPushCounter1++;
led1.on();
// if the current state is LOW then the button
// wend from on to off:
buttonPushCounter1;
// Delay a little bit to avoid bouncing
Blynk.virtualWrite(V1, buttonPushCounter1);
// save the current state as the last state,
//for next time through the loop
led1.off();
lastButtonState1 = buttonState1;
//void pir2() {
buttonState2 = digitalRead(ledPin2);
if (buttonState2 != lastButtonState2) {
if (buttonState2 == HIGH) {
buttonPushCounter2++;
led2.on();
buttonPushCounter2;
led2.off();
Blynk.virtualWrite(V2, buttonPushCounter2);
lastButtonState2 = buttonState2;
//void pir3() {
buttonState3 = digitalRead(ledPin3);
if (buttonState3 != lastButtonState3) {
if (buttonState3 == HIGH) {
buttonPushCounter3++;
led3.on();
buttonPushCounter3;
Blynk.virtualWrite(V3, buttonPushCounter3);
led3.off();
lastButtonState3 = buttonState3;
//void pir4() {
buttonState4 = digitalRead(ledPin4);
if (buttonState4 != lastButtonState4) {
if (buttonState4 == HIGH) {
buttonPushCounter4++;
led4.on();
buttonPushCounter4;
Blynk.virtualWrite(V4, buttonPushCounter4);
led4.off();
lastButtonState4 = buttonState4;
// RESET VOID
BLYNK_WRITE(V6) //Button Widget is writing to pin V6
int buttonresetState = param.asInt();
Blynk.virtualWrite(V7, buttonresetState);
if (buttonresetState == HIGH) {
Blynk.virtualWrite(V5, interacao_pir);
Blynk.syncAll();
buttonresetState=LOW;
// TAX OF CONVERSION VOID
BLYNK_WRITE(V12) //Button Widget is writing to pin V6
int buttonConvState = param.asInt();
if (buttonConvState == HIGH) {
int taxaConv = (( (buttonPushCounter2+buttonPushCounter3+buttonPushCounter4)/buttonPushCounter1));
Blynk.virtualWrite(V11, taxaConv);
Serial.println(taxaConv);
buttonConvState=LOW;
