I was over complicating things. I needed the if conditions to be in a loop for when the switch changed. So I created the whatToDo function and the second timer (I didn’t know you could put multiple things on one timer. Thats good future knowledge). I completely forgot I had my void loop I could just put these if statements in. This works they way I need it to, and it is less complicated.
Your talking about putting the switchCase = 1 and so on for each case, but this is already happening with this part of my code:
BLYNK_WRITE(V1) {
switchState = param.asInt();
switch (param.asInt())
Setting it equal to the param.asInt() does this without having to put it in each case.
Here the full code with the if conditions in the void loop:
SoftwareSerial SerialBLE(10, 11); // RX, TX
BlynkTimer timer1;
void checkPhysicalButton();
char auth[] = "#####";
const int offMode = 4;
const int onMode = 5;
const int runMode = 6;
const int startMode = 7;
const int buttonPin = 2;
int buttonState = 0;
int switchState;
BLYNK_WRITE(V1) {
case 1: // Item 1
Serial.println("Off selected");
break;
case 2: // Item 2
Serial.println("On selected");
break;
case 3: // Item 3
Serial.println("Run selected");
break;
case 4: // Item 4
Serial.println("Start selected");
break;
default:
Serial.println("Unknown item selected");
buttonState = digitalRead(buttonPin);
if(buttonState == HIGH)
++switchState; //add to your button status every press
if(switchState > 4)
switchState = 1; //resets the counter if it is larger than the number of button segments
Blynk.virtualWrite(V1,switchState);
Blynk.syncVirtual(V1); //try this not sure if it will trigger the switch case in the Vbutton fucnction or not
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
pinMode(offMode, OUTPUT);
pinMode(onMode, OUTPUT);
pinMode(runMode, OUTPUT);
pinMode(startMode, OUTPUT);
pinMode(buttonPin, INPUT);
timer1.setInterval(200L, checkPhysicalButton);
timer1.run();
if (switchState == 1){
digitalWrite(offMode, HIGH);
digitalWrite(onMode, LOW);
digitalWrite(runMode, LOW);
digitalWrite(startMode, LOW);
if (switchState == 2){
digitalWrite(offMode, LOW);
digitalWrite(onMode, HIGH);
if (switchState == 3){
digitalWrite(runMode, HIGH);
if (switchState == 4){
digitalWrite(startMode, HIGH);
