Switching the project to the local server
Вопрос, может кто-то сталкивался, есть рабочая система на blynk через интернет, работает замечательно . Если пропадает интернет возможно-ли переключится на локальный сервер (копия)что-бы продолжать мониторить и управлять через локальный сервер, на ум пришло только ещё одна плата с копией под локалку. Может у кого-то есть идеи или готовое решение подскажите, спасибо.
The question is, can someone come across, there is a working system for blink through the Internet, works great. If the Internet disappears, it’s possible that it will switch to a local server (copy) to keep monitoring and managing via the local server, only one more card with a copy under the local store came to mind. Maybe someone has ideas or a ready-made solution, tell me, thank you.
hi!
i’m not sure what is the question, google translate is not very good. however
  • if you want to automatically switch between cloud and local server when there is no internet connection, that is not possible
  • if you want to port an existing project from cloud server to local server, than just clone the cloud server project in app settings, than open the link with your local server account
I wouldn’t be so conservative. It is definitely possible, just requires some efforts.
We don’t provide an out-of the box solution for this scenario in community edition.
well, of course, everything is possible with enough knowledge + work + resources :slight_smile:
but, because this question was asked on the community forum, implicitly i’ve assumed that we are talking about the standard features of the community edition.
