my project about getting location(latitude and longitude) by using esp8266 and gps module,i need my data in excel file which is include realtime data with timestamp and current location as long as the project doesnt turn off.so i use superchart widget to obtain the export to csv function but why i doesnt get email from blynk when i export csv data from superchart??
Not sure of your issue, but reportedly, the SuperChart CSV feature will soon be removed, try the Reports Widget instead.
BTW, do you have regular display widgets showing the data as well as the SuperChart? If you want it to record such, you need to also have other widgets showing the data.
