Superchart: multi-datastream lock to the same auto scale
I’m comparing many similar sensors and plotting them in superchart having multi-datastream. If I set each datastream Y-axis to auto the superchart uses different scale. If I set their Y-axis to the same min/max it works but the Y-axis won’t adjust itself when scrolling left or right. Are there any option that all datastreams lock to the same shared auto scale?
I found the solution.
