Hello everyone,
I’m using SuperChart which is really good, but I can not get a negative value for Min or Max on the Y axis. When I hit the sign - it appears briefly, with a dot, then only the point remains. What is the trick to enter this minus sign?
Thank you Gunner, everything works fine: I just did not understand the operation of the keyboard key that has both a point and the minus sign. To answer your question, I’m using Version 2.27.0, on Blynk Cloud Server.
