Hi guys…
I’ve tried to use binary display in superchart for a while, first in my local server setup (0.35.3 java8 on RPi3, running well and stable) and now with my standard blynk-cloud account, both using the latest android version.
Problem is: I can’t enter a flip value. Entering a value, leaving the screen, checking back in and flip is on zero again. It simply does not save flip.
As a workaround you can raise the min value to the desired flip-value and enter flip (same as min), leave to save, re-enter and enter the real min-value. This saves the flip-value. But just changing flip does not work (for me).
Can you confirm this or am I nuts?
Cheers
Sönke
