First of all, Thank you a lot for your efforts solving this problem.
I updated Blynk App to version 2.26.4 and tested it with my current project.
Unfortunately its still the same issue
- csv export is not resulting in an actual email
- only livechart is showing data, other timebases not (no data yet)
I also encounterd a new problem which was not there before:
I power up my arduino with hc05 modul, open Blynk-App and push start butten -> working as expected, data is visible in livechart. LED on bt05 is switching from quick fkashing to heartbeat.
when i push “stopp” in Blynk-APP bt connection fails to disconnect in most cases (not always). LED on bt05 goes from heartbeat to flashing for around a second and then back to heartbeat. i can’t reconnect Blynk-app ("Something went wrong when connecting with your bt device…).
A physical reboot of hc05 module is needed at this point to reconnect blynk-app.
I am currently testing different ht05 moduls and arduinos, but without success yet.
Are there anything i could do to help you sorting this problem out?
