Suggest to modify Token
It is recommended that the Token in the http://ip-8080 / adminc/users/edit/admin@blynk.io-blynk will be modified.
Here’s why:
The local server data was lost, but Token was saved. If I can modify that, then I don’t need a brush firmware. You only need to modify tokens in the console. Then the device will automatically connect to the server.
Sorry, my English is not good. Here is the text
https://translate.google.com
建议http://ip:8080/admin#/users/edit/admin@blynk.io-Blynk中Token配置为可修改。
原因如下:
有次本地服务器数据丢失,但Token有保存。如果可修改那么我就不需要一个一个重刷固件。而只需要在控制台修改token。那么设备就会自动连上服务端。
抱歉,我英语不好。以下是原文
