I add a styled button to my project to control D1 pin of nodemcu. Styled button does not work. With the same pin number (D1) classic button is working.
I think this is a error.
Interesting… I tested this with a LED and both styled and regular button on same PWM pin. Both had the MIN-MAX set at 0-1
The styled button lit it up dimly… true PWM fashion
The original button just lit it full intensity as expected.
But as soon as I changed both buttons to 0-2, they both lit the LED dimly in PWM fashion… and as expected with increasing values up to 255.
So it appears there is some ON/OFF/PWM logic algorithm that has changed, or is missing, with the new button…
The same happened with me.
Tested on Arduino Mega digital pin 13 (internal LED). Simple on-off toggle.
works with simple button widget, but does not work with Styled button.
App version 2.24.0 Android
Thanks. Seems like a bug with new button. We will check.
This issue is fixed in 2.25.1 release, it should be available very soon to download.
Confirmed working in my tests.
