Struggling with Blynk, millis and loops
Hello Blynk gurus,
I have been trying hard to understand how to integrate Blynk to make it run a program for a defined amount of time using the millis function, when I send a “1” on a virtual pin.
The V0 pin is a push button widget and when depressed it sends the value “1”, otherwise “0”.
The program is actually for running a DC motor but for sake of simplifying the issue, I just want to have the LED turn on and stay on for 5 seconds, then turn off. At the end of this, I want it to return to waiting for the V0 pin to send another “1”.
At the moment, when the ESP connects to the wifi, the LED is off until I send the “1” after which it turns on and stays on indefinitely. Please, if you have a minute, point me to the stupidity that I am making here.
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "mywifi";
char pass[] = "password";
#define ON true
#define OFF false
byte EN = 0; //defining the enable pin on Huzzah
byte ledState = OFF; //setting the starting state
unsigned long interval = 5000; // the time we need to run
unsigned long ledOnTimer = 0; // millis() returns an unsigned long.
void turnOnLED() {     //this is the turn-on routine
  ledState = ON;
  ledOnTimer = millis();
  digitalWrite(EN, HIGH);
void checkLEDState() {    //this routine is the timer routine. It keeps the EN pin HIGH UNLESS the interval time has been reached.
  if (ledState == OFF) {
    digitalWrite(EN, LOW);
    if (millis() - ledOnTimer >= interval) {
      ledState = OFF;
  pinMode(EN, OUTPUT);
  turnOnLED();
BLYNK_WRITE(V0) {
int button = param.asInt(); // read button
if (button == 1) {
  checkLEDState();  //this starts the timer routine above
else {
        ledState = OFF;
This was very helpful, thanks. Iended up using your latch timer example as that is exactly what i was needing. For anybody too lazy to follow the link, get this code:
char auth[] = "xxxxxxxxxx";
char ssid[] = "xxxxxxxxxx";
char pass[] = "xxxxxxxxxx";
int port = 8080;
int Latch;
int Flag;
#define DeviceLED 2 // Built in LED for Wemos or NodeMCU v3, Or 16 for NodeMCU v1
#define LatchRelay 12 //  GPIO12 or D6
  pinMode(DeviceLED, OUTPUT);
  pinMode(LatchRelay, OUTPUT);
  WiFi.begin(ssid, pass);
  Blynk.connect();
//===== LATCH(Relay) & LED PULSE - BLYNK Functions =====
BLYNK_WRITE(V0)  // Virtual button on V0 to activate Relay_LED pulses
  //Serial.println("Latch LED");
  Latch = param.asInt();
  if (Latch == 1 && Flag == 0) {
    Flag = 1;  // Keeps from allowing button press more then once while relay activated
    digitalWrite(LatchRelay, HIGH); // Activate Relay
    timer.setTimer(1000L, blinkMyLEDon, 10);  // Pulse LED routine (LedON/LedOFF) 10 times
    timer.setTimeout(10000L, RelayOFF);  // Deactivare Relay after 10 seconds
  }  // END if
}  // END Blynk Function
void RelayOFF() {
  digitalWrite(LatchRelay, LOW);
  Flag = 0;  // reset flag after relay disables
}  // END Function
void blinkMyLEDon() {
  digitalWrite(DeviceLED, LOW); // Turn ON built in LED (triggered LOW)
  timer.setTimeout(500L, blinkMyLEDoff);  // Run LED OFF routine once in 1/2 second
}  // END Function
void blinkMyLEDoff() {
  digitalWrite(DeviceLED, HIGH); // Turn OFF built in LED (triggered LOW)
}  // END Function
  timer.run(); // This keeps checking the timers to see if then need to be processed
