Even if text does not disappear immediately, when I re-open the app after hours, text disappears.
I hope it will be solved as soon as possible because I use terminal widget as summary of my energy consumption of every day and if text disappears, I lose all my consumption history (to be honest project is not complete and so energy consumpion is not real at the moment )
I have also noticed duplicated text when using terminalā¦ always complete lines as opposed to duplicated characters.
I thought it might have to do with the use of terminal.flush(), but without that, nothing printed at all.
terminal.println(inputString);
terminal.flush();
It did not always print duplicate linesā¦ so it was a little tough to track the reason. so I ended up using Blynk.virtualWrite (Vx, inputString); instead.
And to keep the issue on topic, while I must agree that historical record keeping shouldnāt be entrusted to any basic display type widget (at least mid-long term)ā¦ I also believe they should only show what was sent and not clear until purposefully clearedā¦as long as project isnāt stopped or connection completely drops, requiring restart - as I suspect happens in this caseā¦
However, this situation needs clarificationā¦
@mimmo13 Are you keeping the project running and just āsoftā closing (minimizing or switching to another app)ā¦ not force closing the app itself?
@Dave1829@Gunner I know, terminal widget is not the best choice for historical records. I tried table widget, but i donāt like that new entries go at bottom of the list without autoscroll. In your opinion, which kind of widget can I use to record data?
The problem still exist also using Blynk.virtualWrite (Vx, inputString) . Very often the inputString is duplicated on Terminal widget . No way to solve . I am using a trick to bypass the problem using the AUTOSCROLL option and putting all text in a long single inputString .In this way , when there is a duplication , all the text simply scroll very fast .
Anyway I am still waiting for a definitive solution to this problem .
This āissueā has been popping back a few times, probably for differing reasons and resolved with differing versions of App. Thus, whatever ādefinitiveā solution will probably not happen until they (the developers) release the ānewā version of Blynk.
