@Dmitriy
Yes sure you can see my sketch.
It is here: The sketch is running at ESP8266 Based on ESP-12F from this little device { http://www.electrodragon.com/product/wifi-iot-relay-board-based-esp8266/ }
Thanks in advance.
/// PRE-RELEASE Need some more testing / checking finalising etc ///
/// #define BLYNK_DEBUG // Optional, this enables lots of prints ///
#define WellcomeLine2 "Ver. d0.7"
#define Author "Mike Kranidis"
#define Project "V LAB Oven Control"
/// Vermantia LAB Full Oven Control ///
/// (C) 2016-2017 Mike Kranidis ///
/// Latest change at 03/01/2017 ///
/// #define BLYNK_PRINT Serial ///
/// GPIO14 <==> DS18B20 ///
/// GPIO13 <==> Relay1 ///
/// GPIO12 <==> Relay2 ///
/// WeMos ESP-12E matching ///
/// D0 <==> GPIO16 /// HARDWARE_LED 16
/// D1 <==> GPIO05 /// ( SCL )
/// D2 <==> GPIO04 /// ( SDA )
/// D3 <==> GPIO00 /// ( 10k Pull-up )
/// D4 <==> GPIO02 /// ( WeMos 10k Pull-up, BUILTIN_LED )
/// D5 <==> GPIO14 /// ( SCK ) 4 X DS18B20
/// D6 <==> GPIO12 /// ( MISO ) Relay2 Lower Heater activate on HIGH
/// D7 <==> GPIO13 /// ( MOSI ) Relay1 Upper Heater activate on HIGH
/// D8 <==> GPIO15 /// ( 10k Pull-down )
/// All IO have interrupt/pwm/I2C/one-wire supported(except D0)
/// Blynk related setup ///
/// Blynk color definition
/// http://www.rapidtables.com/web/color/RGB_Color.htm ///
#define GREEN "#23C48E"
#define BLUE "#04C0F8"
#define YELLOW "#ED9D00"
#define RED "#D3435C"
#define DARK_BLUE "#5F7CD8"
#define BLACK "#000000"
#define WHITE "#FFFFFF"
* V0 terminal widget with "Display" label
* V1 virtual switch for activate (start) or deactivate (stop) the Oven and the LED's V1
* V2 virtual switch for activate ESP diagnostics and printing @ rerminal screen
* V3 virtual led1 widget showing the status of upper heater (resistor). When lit the heater is in action V3
* V4 virtual led2 widget showing the status of lower heater (resistor). When lit the heater is in action V4
* V11 Probe01 DS18B20 temperature sensor on History Graph widget on V11
* V12 Probe02 DS18B20 temperature sensor on History Graph widget on V12
* V13 Probe03 DS18B20 temperature sensor on History Graph widget on V13
* V14 Probe04 DS18B20 temperature sensor on History Graph widget on V14
* NO THIS BUTTON REMOVED V20 virtual button for terminal printing on if true or off if false
* V21 RUNning virtual LED
* V22 Slider Widget for setting Oven temperature in the range of 25 ~ 65 Celsius degrees V22
* V23 Value Display Widget to show the selected temperature V23
* V24 Slider Widget for setting Oven EMERGENCYTEMP (for testing, can removed then) V24
* V25 Used to keep timeZone value and to have it across restart ( due to Blynk.syncAll() )
* V26 PIN_UPTIME UPTIME on Value Display widget on V26
* V27 Value Display Widget to show the selected temperature V27
/// OTA dependencies ///
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
/// WiFiManager dependencies ///
#include <DNSServer.h> //Local DNS Server used for redirecting all requests to the configuration portal
#include <ESP8266WebServer.h> //Local WebServer used to serve the configuration portal
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager WiFi Configuration Magic
/// blynk dependencies ///
/// it is used above /// #include <ESP8266WiFi.h>
/// NTP dependencies and declarations///
#include <TimeLib.h>
/// it is used above /// #include <WiFiUdp.h>
// NTP Servers:
static const char ntpServerName[] = "gr.pool.ntp.org";
int timeZone = 2; /// Greek European Time
WiFiUDP Udp;
unsigned int localPort = 8888; // local port to listen for UDP packets
time_t getNtpTime();
/// DS18B20 temperature sensor dependencies and declarations///
/*-----( Import needed libraries )-----*/
// Get 1-wire Library here: http://www.pjrc.com/teensy/td_libs_OneWire.html
#include <OneWire.h>
//Get DallasTemperature Library here: http://milesburton.com/Main_Page?title=Dallas_Temperature_Control_Library
/*-----( Declare Constants and Pin Numbers )-----*/
#define ONE_WIRE_BUS_PIN 14
/*-----( Declare objects )-----*/
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS_PIN);
// Pass our oneWire reference to Dallas Temperature.
/*-----( Declare Variables )-----*/
// Assign the addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
/// lab temperature sensores 1 - 4 ///
DeviceAddress Probe01 = { 0x28, 0xFF, 0xCF, 0xD7, 0x61, 0x16, 0x03, 0x28 }; /// in the format: 0x28, 0xFF, 0x05, 0x40, 0x51, 0x16, 0x04, 0x8D
DeviceAddress Probe02 = { 0x28, 0xFF, 0xE0, 0x8A, 0x61, 0x16, 0x03, 0xFA };
DeviceAddress Probe03 = { 0x28, 0xFF, 0x9E, 0x1D, 0x62, 0x16, 0x03, 0xB6 };
DeviceAddress Probe04 = { 0x28, 0xFF, 0xA4, 0xFB, 0x61, 0x16, 0x03, 0x2B };
/// Variables to hold the temperatures you retrieve via temperature sensors Probe01 .. Probe04
float tempC1, tempC2, tempC3, tempC4, tempC5;
float tempC1old = 40.0, tempC2old = 40.0, tempC3old = 40.0, tempC4old = 40.0;
/// Variables that hold the slider value and the converted to float value ( tempSetting = tempSlider/10 )
int tempSlider;
float tempSetting;
/// Variables that hold the tempoffset in Celsius degrees that the temeperature can overpass the tempSetting
float tempOffset = 0.60;
/// ovenStatus boolean variable true means we need Oven to get action false means no Oven action ///
bool ovenStatus;
/// EMERGENCYTEMP is the maximum allowed temperature that the oven can reach. When this temperature was reached
/// it will shut down the heaters due to deactivation of the Relay1 & Relay2.
float EMERGENCYTEMP = 70.0;
/// Relays 1,2 and initialization activated on 0 false ///
#define Relay1 13
#define Relay2 12
/// define hardware led to GPIO16
#define HARDWARE_LED 16
/// variable to control blinking at hardware led ///
boolean ledBlink = true;
/// Use Virtual pin 26 for uptime display
#define PIN_UPTIME V26
/// totalTemp keeps the mean value for all four sensors like (temp1+temp2+temp3+temp4) / 4
float totalTemp = 0;
char auth[] = "AUTH CODE";
WidgetLED led0(V21); /// RUN? LED
WidgetLED led1(V3); /// Upper Heater LED
WidgetLED led2(V4); /// Lower Heater LED
/// Attach virtual serial terminal to Virtual Pin V0
WidgetTerminal terminal(V0);
/// replace with your channel's thingspeak API key,
/// String apiKey = "080ZWB36ISHGDBXG";
/// const char* server = "api.thingspeak.com";
/// WiFiClient client;
/// start of WiFiManager Global Start here... ////
WiFiManager wifiManager;
/// switch value to control if the terminal printing will be on or off if false ///
boolean termPrint = false;
/// timestamp variable to keep track of millis() unsigned long ticks = millis() / 1000; That is for debugging printings ///
/// unsigned long timestamp;
/// SimpleTimer timer function, check each 5 minutes for the connection. If you lost it then it is doing ESP.reset() ///
void connCheck() {
if(!wifiManager.autoConnect("AutoConnectAP")) {
Serial.println("failed to connect and hit timeout");
//reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(5000);
/// START of SimpleTimer timer activating function blinkLedWidget ///
void blinkLedWidget()
if (led0.getValue()) {
led0.off();
///BLYNK_LOG("LED1: off");
if(WiFi.RSSI() < -83){
Blynk.setProperty(V21, "color", RED);
else if(WiFi.RSSI() > -57){
Blynk.setProperty(V21, "color", GREEN);
else{
Blynk.setProperty(V21, "color", YELLOW);
led0.on();
///BLYNK_LOG("LED0: on");
/// put the routine here to blink HARDWARE_LED gp 16 each second ///
if (ledBlink) {
digitalWrite(HARDWARE_LED, !(digitalRead(HARDWARE_LED)));
/// END of SimpleTimer timer activating function blinkLedWidget ///
/// START of diagnostics function ///
void diagnostics()
/// diagnostics print here ///
/// termPrint=false; /// shall I implement in this sketch ???
terminal.printf("\nBlynk %s / %s / %s\n%s\n", BLYNK_VERSION, Author, WellcomeLine2, Project);
/// terminal.println(WellcomeLine2);
// terminal.println(Version);
/// terminal.println(Project);
terminal.print("Last RST?: ");
terminal.println (ESP.getResetReason());
/// not working /// terminal.printf("Last RST?: %s \n", ESP.getResetReason());
String chipID = String(ESP.getChipId(), HEX);
char charChipID[10];
chipID.toCharArray(charChipID, sizeof(charChipID));
terminal.printf("ESP ID: %d / in HEX: %s\n", ESP.getChipId(),charChipID);
terminal.printf("ESP free heap? : %d \n", ESP.getFreeHeap());
terminal.printf("WiFi Signal:%ddBm / IP:", WiFi.RSSI());
terminal.println(WiFi.localIP());
///terminal.print("ESP flash chip frequency? : ");
///terminal.println(ESP.getFlashChipSpeed()); /// returns the flash chip frequency, in Hz.
// Ensure everything is sent
terminal.flush();
/// END of diagnostics function ///
/// START of clock (RTC) function with printing ///
void clockDisplay()
// You can call hour(), minute(), ... at any time
// Please see Time library examples for details
/// String currentTime = String(hour()) + ":" + minute() + ":" + second();
/// String currentDate = String(day()) + "/" + month() + "/" + year();
/// s for second, m for minute, h for hour, d for day, M for month ///
String s, m, h, d, M;
if (second() < 10) { s = "0" + String(second()); }
else { s = String(second()); }
if (minute() < 10) { m = "0" + String(minute()); }
else { m = String(minute()); }
if (hour() < 10) { h = "0" + String(hour()); }
else { h = String(hour()); }
if (day() < 10) { d = "0" + String(day()); }
else { d = String(day()); }
if (month() < 10) { M = "0" + String(month()); }
else { M = String(month()); }
String currentTime = String(h) + ":" + m + ":" + s;
String currentDate = String(d) + "/" + M + "/" + year();
///terminal.print("Current time: ");
if(termPrint) terminal.print(currentDate);
if(termPrint) terminal.print(" ");
///terminal.println();
if(termPrint) terminal.println(currentTime);
///terminal.print(" ");
if(termPrint) terminal.flush();
/// END of clock (RTC) function with printing ///
void sendNTPpacket(IPAddress &address);
/// START of DS18B20 temperature sensors printing Function printTemperature ///
void printTemperature(DeviceAddress deviceAddress, int Vpin)
float tempC = sensors.getTempC(deviceAddress);
if (tempC == -127.00)
///Serial.print("Error getting temperature ");
terminal.println("Error getting temperature ");
terminal.flush();
///Serial.print(tempC);
///Serial.println(" °C");
/// Send it to the server and to history widget
Blynk.virtualWrite(Vpin, tempC);
if(termPrint) {
///terminal.printf("",);
///terminal.print("Vpin:");
terminal.print(Vpin);
terminal.print(" => T=");
terminal.print(tempC);
terminal.println("°C");
terminal.flush();
///Serial.print(" F: ");
///Serial.print(DallasTemperature::toFahrenheit(tempC));
/// END of DS18B20 temperature sensors printing Function printTemperature ///
/// START of DS18B20 temperature sensors process Function reportTemperature() this will be running using simpletimer each ex 5 seconds
/// also be used to update PIN_UPTIME V26 for ESP's up time also update the totalTemp value ///
void reportTemperature()
clockDisplay();
///Serial.println();
///Serial.print("Number of Devices found on bus = ");
///Serial.println(sensors.getDeviceCount());
///Serial.print("Getting temperatures... ");
// Command all devices on bus to read temperature
///Serial.print("Probe 01 temperature is: ");
printTemperature(Probe01,11); /// Probe01 holds the temperature in C for 1sr DS18B20 temperature sensor ///
///Serial.print("Probe 02 temperature is: ");
printTemperature(Probe02,12); /// Probe02 holds the temperature in C for 2nd DS18B20 temperature sensor ///
///Serial.print("Probe 03 temperature is: ");
printTemperature(Probe03,13); /// Probe03 holds the temperature in C for 3rd DS18B20 temperature sensor ///
///Serial.print("Probe 04 temperature is: ");
printTemperature(Probe04,14); /// Probe04 holds the temperature in C for 4th DS18B20 temperature sensor ///
/// put this inside the reportTemperature function that is simpletimer activated each 5 seconds
// This command writes ESP's uptime in seconds to Virtual Pin (V26) PIN_UPTIME
/// presentation value reset (moduled %) each day = 86400 , week = 604800 so put this value on module ///
ticks = ticks % 1209600; /// modulo each 2 weeks ///
Blynk.virtualWrite(PIN_UPTIME, ticks);
totalTemp = (tempC1 + tempC2 + tempC3 + tempC4) / 4;
Blynk.virtualWrite(V27, totalTemp); /// send the totalTemp value to Value Display Widget ///
/// END of DS18B20 temperature sensors process Function reportTemperature() ///
/// START of actionOnTemperature Function take action acording the temperature this will be running using simpletimer each ex 1.5 seconds ///
/// measure all the sensors and compare the measured value with the demanded value then start or stop the heater accordingly ///
/// the related variables are: Relay1 with V3 LED, Relay2 with V4 LED demanting temerature tempSetting
void actionOnTemperature()
/// Command all devices on bus to read temperature
tempC1 = sensors.getTempC(Probe01);
if (tempC1 == -127.00)
tempC1 = tempC1old; /// if the measure is failed then use the old value ///
if(termPrint) {
terminal.println("temp1 faild ");
terminal.flush();
tempC1old = tempC1;
tempC2 = sensors.getTempC(Probe02); /// if the measure is failed then use the old value ///
if (tempC2 == -127.00)
tempC2 = tempC2old;
if(termPrint) {
terminal.println("temp2 faild ");
terminal.flush();
tempC2old = tempC2;
tempC3 = sensors.getTempC(Probe03); /// if the measure is failed then use the old value ///
if (tempC3 == -127.00)
tempC3 = tempC3old;
if(termPrint) {
terminal.println("temp3 faild ");
terminal.flush();
tempC3old = tempC3;
tempC4 = sensors.getTempC(Probe04); /// if the measure is failed then use the old value ///
if (tempC4 == -127.00)
tempC4 = tempC4old;
if(termPrint) {
terminal.println("temp4 faild ");
terminal.flush();
tempC4old = tempC4;
if(tempC1 > EMERGENCYTEMP || tempC2 > EMERGENCYTEMP || tempC3 > EMERGENCYTEMP || tempC4 > EMERGENCYTEMP)
ovenStatus = false;
digitalWrite(HARDWARE_LED, LOW); /// switch off the internal LED
/// switch off Relay1, Relay2, led1, led2 ///
digitalWrite(Relay1, LOW); /// deactivate the Relay1
digitalWrite(Relay2, LOW); /// deactivate the Relay2
led1.off(); led2.off();
Blynk.virtualWrite(V1, 0);
terminal.println("*********************");
terminal.println("* SOS TEMP. SHUTOFF *");
terminal.println("* reactivate PWR/sw *");
terminal.flush();
Blynk.syncVirtual(V1);
if(ovenStatus == true) {
float offsetHigh = tempSetting + tempOffset;
float offsetLow = tempSetting - tempOffset;
if(tempC1 > offsetHigh || tempC2 > offsetHigh)
/// we have bigger temperature that the demanded on the upper part of the oven, switch off Relay1 and LED V3 ///
/// LED V3 Upper Heater off
led1.off();
{ /// we have lower temperature that the demanded on the upper part of the oven, switch on Relay1 and LED V3 ///
if(tempC1 < offsetLow || tempC2 < offsetLow)
digitalWrite(Relay1, HIGH); /// activate the Relay1
/// LED V3 Upper Heater on
///Blynk.virtualWrite(V3, HIGH);
led1.on();
if(tempC3 > offsetHigh || tempC4 > offsetHigh)
/// we have bigger temperature that the demanded on the lower part of the oven, switch off Relay2 and LED V4 ///
/// LED V4 lower Heater off
///Blynk.virtualWrite(V4, 0);
led2.off();
/// we have lower temperature that the demanded on the lower part of the oven, switch on Relay2 and LED V4 ///
if(tempC3 < offsetLow || tempC4 < offsetLow)
digitalWrite(Relay2, HIGH); /// activate the Relay2
/// LED V4 lower Heater on
///Blynk.virtualWrite(V4, HIGH);
led2.on();
} /// end of if(ovenStatus == true)
} /// END of actionOnTemperature Function take action acording the temperature this will be running using simpletimer each ex 2 seconds ///
/// ===> START OF SETUP <=== ///
Serial.println("Booting...");
//WiFiManager
//Local initialization. Once its business is done, there is no need to keep it around
/// WiFiManager wifiManager;
/// wifiManager.setConfigPortalTimeout(180);
//fetches ssid and pass from eeprom and tries to connect
//if it does not connect it starts an access point with the specified name
//here "AutoConnectAP"
//and goes into a blocking loop awaiting configuration
wifiManager.autoConnect("AutoConnectAP");
Serial.println("connected...yesss! :)");
// Port defaults to 8266
// ArduinoOTA.setPort(8266);
// Hostname defaults to esp8266-[ChipID]
// ArduinoOTA.setHostname("myesp8266");
// No authentication by default
// ArduinoOTA.setPassword((const char *)"123");
ArduinoOTA.onStart([]() {
Serial.println("Start");
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.begin();
Serial.println("Ready");
Serial.print("IP address: ");
/// consider to use Blynk.config(auth); that is now ssid, password hard code specific ///
/// due to WiFiManager framework the bellow credentials are not needed anymore... ///
/// Blynk.begin(auth, ssid, password);
Blynk.config(auth);
// Wait until connected
/// START of SimpleTimer timer Functions
// Check the connection every 5 minutes (300 seconds). If not connected run
/// TEMPORARY (?) DISABLED /// timer.setInterval(300000L, connCheck);
/// This blink LED function be called every 2 seconds
timer.setInterval(2000L, blinkLedWidget);
/// This call reportTemperature() function every 5 seconds also be used to update PIN_UPTIME V26 for ESP's up time also update the totalTemp value
timer.setInterval(5000L, reportTemperature);
/// This call actionOnTemperature() function every 1.5 seconds
timer.setInterval(1500L, actionOnTemperature);
/// END of SimpleTimer timer Functions
terminal.println(" ");
terminal.println(Author);
terminal.print("ESP ID? : ");
terminal.println (ESP.getChipId());
terminal.flush();
/// NTP related ///
Serial.println("Starting UDP");
Udp.begin(localPort);
Serial.print("Local port: ");
Serial.println(Udp.localPort());
Serial.println("waiting for sync");
setSyncProvider(getNtpTime);
setSyncInterval(300); /// set sync timer at 300 seconds = 5 minutes
/// DS18B20 temperature sensors section ///
Serial.print("Initializing Temperature Control Library Version ");
Serial.println(DALLASTEMPLIBVERSION);
// Initialize the Temperature measurement library
sensors.begin();
/// set the resolution to ANY bit you like - Valid values are 9, 10, 11 or 12 bit.
/* Resolution Increment Time
9 bit 0.5 degrees C 93.75 mSec
10 bit 0.25 degrees C 187.5 mSec
11 bit 0.125 degrees C 375 mSec
12 bit 0.0625 degrees C 750 mSec
sensors.setResolution(Probe01, 10);
sensors.setResolution(Probe02, 10);
sensors.setResolution(Probe03, 10);
sensors.setResolution(Probe04, 10);
// confirm that we set that resolution by asking the DS18B20 to repeat it back
Serial.print("Sensor 1 Resolution: ");
Serial.println(sensors.getResolution(Probe01), DEC);
Serial.println();
Serial.print("Sensor 2 Resolution: ");
Serial.println(sensors.getResolution(Probe02), DEC);
Serial.println();
Serial.print("Sensor 3 Resolution: ");
Serial.println(sensors.getResolution(Probe03), DEC);
Serial.println();
Serial.print("Sensor 4 Resolution: ");
Serial.println(sensors.getResolution(Probe04), DEC);
Serial.println();
/// initialization of Upper Heater virtual LED (V3) and
/// Lower Heater virtual LED (V4) virtual leds ( switch both OFF )
///Blynk.virtualWrite(V3, 0); Blynk.virtualWrite(V4, 0);
/// initialization of Relay1, Relay2 activate on HIGH, so we putt them on LOW
pinMode(Relay1, OUTPUT); /// Upper Heater Relay ///
pinMode(Relay2, OUTPUT); /// Lower Heater Relay ///
pinMode(HARDWARE_LED, OUTPUT); /// set the hardware led GPIO pin as output
digitalWrite(HARDWARE_LED, LOW); /// deactivate (switch off) the hardware led
/// initialization of ovenStatus
ovenStatus = true;
/// ===> END OF SETUP <=== ///
/// START of clearScreen function ///
void clearScreen() /// LCD & terinal clear ///
for(int i=1; i<8; i++) {
terminal.println();
terminal.flush();
/// END of crearScreen function ///
// You can send commands from Terminal to your hardware. Just use
// the same Virtual Pin as your Terminal Widget
BLYNK_WRITE(V0)
// if you type "Marco" into Terminal Widget - it will respond: "Polo:"
String getString = param.asStr();
getString.trim(); /// cut off the blank spece(s) at the end of the string ///
///getString.toUpperCase();
if (getString.equalsIgnoreCase("MARCO")) {
terminal.println("You said: 'Marco'") ;
terminal.println("I said: 'Polo'") ;
return;
} else if (getString.equalsIgnoreCase("Clear") || getString.equalsIgnoreCase("Cls")) {
clearScreen();
return;
} else if (getString.startsWith("tz")) {
timeZone = (getString.substring(2)).toInt();
Blynk.virtualWrite(V25, timeZone);
setSyncProvider(getNtpTime); /// this acting as "syncNow" !
return;
} else if (getString.equalsIgnoreCase("restart")) {
terminal.println("OK I do restart !");
terminal.flush();
yield(); yield(); delay(500);
ESP.restart();
} else if (getString.equalsIgnoreCase("Diags")) {
///terminal.println("You said: Diags , OK!");
diagnostics();
return;
} else if (getString.equalsIgnoreCase("tpoff")) {
terminal.println("terminal print off...");
terminal.flush();
termPrint = false;
return;
} else if (getString.equalsIgnoreCase("tpon")) {
terminal.println("terminal print on...");
terminal.flush();
termPrint = true;
return;
} else if (getString.equalsIgnoreCase("?") || getString.equalsIgnoreCase("help")) {
terminal.println("The regognised commands are: ");
terminal.println("clear/cls, diags, tpoff, tpon, tz2/tz3 restart");
terminal.flush();
return;
// Send it back
terminal.print("You said (getString): ");
terminal.println(getString);
terminal.print("You said : ");
terminal.write(param.asStr(), param.getLength());
terminal.println();
terminal.flush();
/// start routine for V1 virtual switch for activate (start) or deactivate (stop) the Oven ///
BLYNK_WRITE(V1)
if (param.asInt()) {
ovenStatus = true;
digitalWrite(HARDWARE_LED, HIGH); /// switch on the internal LED
termPrint=true;
else {
ovenStatus = false;
termPrint=false;
/// end routine for V1 virtual switch for activate (start) or deactivate (stop) the Oven ///
/// start routine for terminal printing control using the termPrint boolean value ///
BLYNK_WRITE(V20)
termPrint=true;
else {
/// do nothing ///
termPrint=false;
/// end of routine for manual (on demand) requesting OTA The Virtual Button SW V20 is used ///
BLYNK_WRITE(V2)
termPrint=false;
diagnostics();
termPrint=true;
// Every time we connect to the cloud synchronize some of the values from Widgets...
BLYNK_CONNECTED() {
/// Blynk.syncVirtual(V10);
Blynk.syncVirtual(V1); Blynk.syncVirtual(V2); Blynk.syncVirtual(V3); Blynk.syncVirtual(V4); Blynk.syncVirtual(V5); Blynk.syncVirtual(V6); Blynk.syncVirtual(V7); Blynk.syncVirtual(V8);
Blynk.syncVirtual(V11); Blynk.syncVirtual(V12); Blynk.syncVirtual(V13); Blynk.syncVirtual(V14); Blynk.syncVirtual(V15); Blynk.syncVirtual(V16); Blynk.syncVirtual(V17); Blynk.syncVirtual(V18);
// This function will run every time Blynk connection is established
BLYNK_CONNECTED() {
///if (isFirstConnect) {
// Request Blynk server to re-send latest values for all pins
Blynk.syncAll();
// You can also update an individual Virtual pin like this:
//Blynk.syncVirtual(V0);
/// isFirstConnect = false;
/// START of temperature SLIDER reading ///
BLYNK_WRITE(V22)
tempSlider = param.asInt(); // assigning incoming value from pin V22 to a variable
tempSetting = tempSlider / 10.0;
Blynk.virtualWrite(V23, tempSetting); /// send the tempSetting value to TEMP SET Value Display Widget ///
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
/// END of temperature SLIDER reading ///
/// START of EMERGENCYTEMP SLIDER reading (for testing, can removed then) ///
BLYNK_WRITE(V24)
int sliderValue = param.asInt(); // assigning incoming value from pin V22 to a variable
EMERGENCYTEMP = sliderValue / 10.0;
/// END of EMERGENCYTEMP SLIDER reading (for testing, can removed then) ///
// START of restoring timeZone value from server
BLYNK_WRITE(V25)
timeZone = param.asInt();
// END of restoring timeZone value from server
/// ===> START OF LOOP <=== ///
/// just as reminder here: mySwitch.switchOn(syscode, outletA) ; ///
/// mySwitch.switchOff(syscode, outletA); ///
ArduinoOTA.handle();
/// ===> END OF LOOP <=== ///
/*-------- START of NTP code ----------*/
const int NTP_PACKET_SIZE = 48; // NTP time is in the first 48 bytes of message
byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming & outgoing packets
time_t getNtpTime()
IPAddress ntpServerIP; // NTP server's ip address
while (Udp.parsePacket() > 0) ; // discard any previously received packets
Serial.println("Transmit NTP Request");
// get a random server from the pool
WiFi.hostByName(ntpServerName, ntpServerIP);
Serial.print("ntp Server Name: ");
Serial.print(ntpServerName);
Serial.print(" IP: ");
Serial.println(ntpServerIP);
sendNTPpacket(ntpServerIP);
uint32_t beginWait = millis();
while (millis() - beginWait < 1500) {
int size = Udp.parsePacket();
if (size >= NTP_PACKET_SIZE) {
Serial.println("Receive NTP Response");
Udp.read(packetBuffer, NTP_PACKET_SIZE); // read packet into the buffer
unsigned long secsSince1900;
// convert four bytes starting at location 40 to a long integer
secsSince1900 = (unsigned long)packetBuffer[40] << 24;
secsSince1900 |= (unsigned long)packetBuffer[41] << 16;
secsSince1900 |= (unsigned long)packetBuffer[42] << 8;
secsSince1900 |= (unsigned long)packetBuffer[43];
return secsSince1900 - 2208988800UL + timeZone * SECS_PER_HOUR;
Serial.println("No NTP Response :-(");
return 0; // return 0 if unable to get the time
// send an NTP request to the time server at the given address
// set all bytes in the buffer to 0
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
packetBuffer[0] = 0b11100011; // LI, Version, Mode
packetBuffer[1] = 0; // Stratum, or type of clock
packetBuffer[2] = 6; // Polling Interval
packetBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
Udp.beginPacket(address, 123); //NTP requests are to port 123
Udp.write(packetBuffer, NTP_PACKET_SIZE);
Udp.endPacket();
/*-------- END of NTP code ----------*/
