I’m just getting to grips with IoT from the excellent v0.1.
It might be a C thing (I’m no C coder, I just do assembly), but if I press a switch on the app, the BLINK_WRITE function associated with that virtual port (datastream) runs. I find I can copy the state (integer 0/1 in this case) into a variable and use that variable to immediately set an output pin state.
However, if I come back to use that variable in my 1 second event refresh loop, its state has been lost.
If I make a copy of its state within the BLYNK_WRITE function, that is remembered!
The sketch below says it all - if I copy both variables into new datastreams and look at them on the app, only the copy changes state.
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_DEVICE_NAME ""
#define BLYNK_AUTH_TOKEN ""
char ssid[] = "";
char pass[] = "";
int IRBoostOn = HIGH; //D0 High = Relay 3 OFF
int IRBoostCopy = HIGH;
BLYNK_WRITE(V0) //IRBoost Switch
int IRBoostOn = param.asInt();
digitalWrite(D0,IRBoostOn);
IRBoostCopy = IRBoostOn; //because IRBoostOn state does not seem to carry over!!!
void myTimerEvent()
Blynk.virtualWrite(V1, IRBoostOn);
Blynk.virtualWrite(V2, IRBoostCopy);
pinMode(D0,OUTPUT); //IR Boost
