hi,
How i can run automatically in the background dht11 script @ rpi. i can manually run but automatic does not work.
my rc.local file;
#!/bin/sh -e
rc.local
This script is executed at the end of each multiuser runlevel.
Make sure that the script will “exit 0” on success or any other
value on error.
In order to enable or disable this script just change the execution
bits.
By default this script does nothing.
Print the IP address
_IP=$(hostname -I) || true
if [ “$_IP” ]; then
printf “My IP address is %s\n” “$_IP”
fi
sudo NODE_PATH=“/usr/local/lib/node_modules” node ./blynk-sensor-test.js --token=mytoken &
chmod No such file or directory error… i’m trying four days
pi@raspberrypi:~ $ sudo chmod +x blynk-sensor-test.sh
chmod: blynk-sensor-test.sh''e erişilemedi: Böyle bir dosya ya da dizin yok pi@raspberrypi:~ $ sudo chmod +x blynk-sensor-test.js pi@raspberrypi:~ $ sudo chmod +x blynk-sensor-test.sh chmod: blynk-sensor-test.sh’'e erişilemedi: Böyle bir dosya ya da dizin yok
pi@raspberrypi:~ $ sh ./blynk-sensor-test.sh
sh: 0: Can’t open ./blynk-sensor-test.sh
pi@raspberrypi:~ $ sh ./blynk-sensor-test.js
./blynk-sensor-test.js: 1: ./blynk-sensor-test.js: Syntax error: “(” unexpected
pi@raspberrypi:~ $
