Standalone esp8266 sample
Hi, is the general of use for standalone esp8266 in that we get connected and then start adding stuff to this example? As it is it just connects to wifi and that’s it, correct?
Exactly. We provide examples for use-cases with Ethernet shield, as well as examples for platforms/connection types.
You should mix/extend example for your platform to get the desired functionality. We worked hard to make it super-simple! :smile:
I think this also shows the extensibility of implenetation.
Okay I got the virtual LED Blink working over the esp8266 - I still think it would be a good idea to have the esp8266 standalone blink a virtual led at a minimum.
I started with the esp8266, probably not most peoples first choice to get going using Blynk. :smiley:
