Sparkfun Blynk Board Reconfigure Not working
Hello. Im having an issue related to reconfiguring the sparkfun blynk board. The standalone board.
I cannot get it to broadcast its wifi Blynk Me to reconfigure.
I have uploaded a few other sketches with success and all is well with the app etc. Turning pins high low etc.
I would like to be able to hold the zero button and reset it that way instead of using the arduino IDE to input wifi details etc.
Is there a way to revert it to its original state as I assume once I uploaded new code it wiped the factory preset?? no??
EDIT*
Iv reuploaded the Template esp8266 sketch and its blinking in this state
case MODE_WAIT_CONFIG: return beatLED(COLOR_BLUE, (int[]){ 50, 500 });
I cannot seem to get it into AP mode.
Am I missing a trick here? or could you help me out.
Regards
Please post your Serial Monitor logs (speed 115200)
[843] Hardware v1.0.0
[843] Firmware v1.0.1
[1344] AP SSID: Our Product
[1344] AP IP: 192.168.4.1
[1345] AP URL: our-product.cc
See, it looks OK
Maybe, But as I mentioned above. It is not broadcasting. When I go to find the BlynkMe wifi signal, there is none. If I hold down for 4 seconds it blinks white quick, If released it goes back to quick blink blue. If I hold down for longer the led goes blank completely.
Whoops. “our product” is the name of the board. I was Looking for BlynkMexxxx to join.
All is well. And working.
Yes, that’s the point :wink:
