Spark Core Error
I added the library and code for Blynk, but when I compile I get the errors below when I add the blink run command to the main loop.
Error:
In file included from blynk/BlynkSparkCore.h:16:0,
from blynk/BlynkSimpleSparkCore.h:14,
from blynk/blynk.h:2,
from the_user_app.cpp:2:
blynk/BlynkApiSparkCore.h:28:6: warning: always_inline function might not be inlinable [-Wattributes]
void BlynkApi<Proto>::processCmd(const void* buff, size_t len)
In file included from blynk/BlynkSparkCore.h:17:0,
blynk/BlynkProtocol.h:154:6: warning: always_inline function might not be inlinable [-Wattributes]
void BlynkProtocol<Transp>::processInput(void)
/opt/gcc_arm/bin/../lib/gcc/arm-none-eabi/4.8.4/../../../../arm-none-eabi/bin/ld: 320a3c152316124f73565ebb243be9bc619a52d373f552c0f730d1144ee8.elf section `.init_array' will not fit in region `FLASH'
/opt/gcc_arm/bin/../lib/gcc/arm-none-eabi/4.8.4/../../../../arm-none-eabi/bin/ld: region `FLASH' overflowed by 56 bytes
collect2: error: ld returned 1 exit status
make: *** [320a3c152316124f73565ebb243be9bc619a52d373f552c0f730d1144ee8.elf] Error 1
The message says your code is too big to fit Spark.
Try using a simple example first:
https://build.spark.io/libs/55529a83593a806ff3000eb2/tab/SparkCore.ino (select SparkCore.ino)
Also, check this thread:
Thanks!
