Awesome, lots of great ideas and tips here, thnx!
thx for sharing, alot of good stuff in your project.
for now I learned how simple it is to monitor the wifi signal, wil be comming back to grab some more learning
Hi @Jamin I got some MAX471 and now I am having difficulties to (analog)read to trigger relay, tried dozens of example but end up with nothing. Can you help me with that if its possible ?
My advice is buy an INA219 and ditch analog input.
So it will be easy to use INA219 than MAX471 ?
meanwhile I am ditching little push up will be great
Yup its digital I2C connection instead of an analog voltage signal.
Check out my Power Monitor project using the INA219 and Blynk.
Definitely I will check, thanks ![]()
Wow Very Nice Project … I Will Make This One BTW
What is IP 192.168.1.2
This Is Device Static IP Or Router Ip
Please Help Me
It’s the server ip.
Get the latest code from my GitHub
Not sure but I’m half asleep in bed so def user error
All Is Ok i Uploaded Code in My NodeMCU …With Auth Code And My Router Wifi SSID And Password
Its Show In Router Statistic IP With Hostname " ESP_0078B0" Router Admin Page IP " 192.168.1.105"
But Its Show Device Offline And Wasn’t Online Yet
What Is For Setting.h
define SERVER IPAddress(192, 168, 1, 2) This Is Router Gateway , My Router IP Is 192.168.1.1
Please Help Me I’m New Please I Hope U Understand My Problem And Not Angry
Waiting For Great Info And Solution
Are you running a local server?
if not, go to settings.h and comment out the line
#define USE_LOCAL_SERVER
like so
//#define USE_LOCAL_SERVER
Settings.h is where ALL settings are located… you will see the settings.h tab in your IDE.
No Master Not Running A Local Server How To Setup It And I Must Need It ? Please Help Me Details Step By Step Info What I Need To Do First . I Hope U Little Free Time For Me
Nah just use the Cloud Server provided by Blynk. Local server is only for more advanced users. You can try it one day im sure ![]()
Just comment out that line i mentioned in my post above, then compile and it will use cloud server instead and just ignore the ipaddress in settings.h
Ok Master …
Go to github and download the latest code. I just updated it now to make it easier.
You should not have to change anything. It will connect to Blynk’s Cloud Server by default
Many Thanks Master
Its Show Error While Compile :
C:\Users\MANORANJAN\Desktop\ESP8266-Remote-Blynk-Switch\ESP8266-Remote-Blynk-Switch.ino: In function ‘void setup()’:
ESP8266-Remote-Blynk-Switch:63: error: expected primary-expression before ‘)’ token
Blynk.begin(AUTH, WIFI_SSID, WIFI_PASS, );
exit status 1
Whoops, error.
replace that line with this one:
Blynk.begin(AUTH, WIFI_SSID, WIFI_PASS);
Github repo updated.
Many Thanks Master
Now Working Fine
I Will Wiring 2moro And Update In This post …
