[SOLVED] ZeRGBa widget problem
i have a problem setting ZeRGBa widget pins
my dashboard based on Arduino nano with ESP-01 as Soft shield , the problem is when i’am selecting the pins for each color the pin is not selected , and when i go to the next color pin its not showing the previous selected pin as busy.
i had my RGB LED connected as below (R/G/B) - pins (9/10/11)
but when i use sliders for each color it’s working fine without any problem.
i have the latest android App , and Blynk v0.3.2-beta library
It’s fixed. Will be available in next release
Thanks for reporting :hand:
I’ve passing the same issue. I’m using the 1.0 RC11, still waiting for the update.
