Hello Folks…
This is an old thread but is relevant to what I am seeing so replying to it.
I have just recently started to use the wifimanager library and am also reading/ researching more about it. Special thanks to tzapulica for creating this library… This is an awesome capability added for us Blynkers. Well done!
I am having a similar crash issue as mentioned on this thread when using the WifiManager in my code. If I use the code in the example on GitHub, I have no issues.
Has anyone seen this? Any suggestions on why this might be causing.
Here are my details,
Hardware- ESP8266/Adafruit Huzzah feather. Flash- 3M SPIFFS
Blynk V0.4.7
ESP8266 Library: V2.3
Mobile Phone: iOS
Arduino IDE: 1.6.9
Here is a piece from my code. I can publish the entire code aswell.
#include "HX711.h"
#include <elapsedMillis.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <DNSServer.h> //Local DNS Server used for redirecting all requests to the configuration portal
#include <ESP8266WebServer.h> //Local WebServer used to serve the configuration portal
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager WiFi Configuration Magic
WiFiManager wifiManager; //Initialize WifiManager library
wifiManager.autoConnect("Mynetwork");
wifiManager.setConfigPortalTimeout(180); // after 3 minutes try to autoconnect again
//Blynk.begin(auth, ssid, pass);
Blynk.config(auth);
if(Blynk.connected()){
lcd.clear ();
lcd.print(0,0," Connected to");
lcd.print(0,1," Blynk");
if(!Blynk.connected()){
lcd.clear ();
lcd.print(0,0,"Error- Not ");
lcd.print(0,1,"connected to Blynk");
//Serial.print("get value: \t\t");
//Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight (not set yet)
scale.set_scale(calibration_factor); //This value is obtained by using the SparkFun_HX711_Calibration sketch
//scale.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
rtc.begin();
timer.setInterval(10000L,sendWeight); // wakeup send weight data after 1 second and then sleep again
//timer.setInterval(60000L, sleepESP);
Here is the error I get after I upload to the Adafruit Huzzah.
*WM:
*WM: AutoConnect
*WM: Connecting as wifi client...
*WM: Using last saved values, should be faster
*WM: Connection result:
*WM: 1
*WM: SET AP STA
*WM:
*WM: Configuring access point...
*WM: GasitDone
*WM: AP IP address:
*WM: 192.168.4.1
*WM: HTTP server started
Soft WDT reset
ctx: cont
sp: 3fff0530 end: 3fff0c70 offset: 01b0
>>>stack>>>
3fff06e0: 00000000 00000000 3fff0b80 40209191
3fff06f0: 3ffef9c0 00000000 3fff0b80 4020a02a
3fff0700: 3ffefb5c 00000124 00000124 4010020c
3fff0710: 00000001 3ffe8867 3fff074c 4010068c
3fff0720: 3ffe8902 4024448a 3ffefb80 00000000
3fff0730: 00000001 3ffe8867 3fff0b80 4020a179
3fff0740: 00000000 00000000 00000000 00000000
3fff0750: 00000000 00000000 3ffefb80 4020a89c
3fff0760: feefeffe feefeffe 3fff0b80 3ffefc3c
3fff0770: 3fffdad0 00000000 3fff0b80 402033da
3fff0780: feefeffe feefeffe feefeffe feefeffe
3fff0790: feefeffe feefeffe feefeffe feefeffe
3fff07a0: feefeffe feefeffe feefeffe feefeffe
3fff07b0: feefeffe feefeffe feefeffe feefeffe
3fff07c0: feefeffe feefeffe feefeffe feefeffe
3fff07d0: feefeffe feefeffe feefeffe feefeffe
3fff07e0: feefeffe feefeffe feefeffe feefeffe
3fff07f0: feefeffe feefeffe feefeffe feefeffe
3fff0800: feefeffe feefeffe feefeffe feefeffe
3fff0810: feefeffe feefeffe feefeffe feefeffe
3fff0820: feefeffe feefeffe feefeffe feefeffe
3fff0830: feefeffe feefeffe feefeffe feefeffe
3fff0840: feefeffe feefeffe feefeffe feefeffe
3fff0850: feefeffe feefeffe feefeffe feefeffe
3fff0860: feefeffe feefeffe feefeffe feefeffe
3fff0870: feefeffe feefeffe feefeffe feefeffe
3fff0880: feefeffe feefeffe feefeffe feefeffe
3fff0890: feefeffe feefeffe feefeffe feefeffe
3fff08a0: feefeffe feefeffe feefeffe feefeffe
3fff08b0: feefeffe feefeffe feefeffe feefeffe
3fff08c0: feefeffe feefeffe feefeffe feefeffe
3fff08d0: feefeffe feefeffe feefeffe feefeffe
3fff08e0: feefeffe feefeffe feefeffe feefeffe
3fff08f0: feefeffe feefeffe feefeffe feefeffe
3fff0900: feefeffe feefeffe feefeffe feefeffe
3fff0910: feefeffe feefeffe feefeffe feefeffe
3fff0920: feefeffe feefeffe feefeffe feefeffe
3fff0930: feefeffe feefeffe feefeffe feefeffe
3fff0940: feefeffe feefeffe feefeffe feefeffe
3fff0950: feefeffe feefeffe feefeffe feefeffe
3fff0960: feefeffe feefeffe feefeffe feefeffe
3fff0970: feefeffe feefeffe feefeffe feefeffe
3fff0980: feefeffe feefeffe feefeffe feefeffe
3fff0990: feefeffe feefeffe feefeffe feefeffe
3fff09a0: feefeffe feefeffe feefeffe feefeffe
3fff09b0: feefeffe feefeffe feefeffe feefeffe
3fff09c0: feefeffe feefeffe feefeffe feefeffe
3fff09d0: feefeffe feefeffe feefeffe feefeffe
3fff09e0: feefeffe feefeffe feefeffe feefeffe
3fff09f0: feefeffe feefeffe feefeffe feefeffe
3fff0a00: feefeffe feefeffe feefeffe feefeffe
3fff0a10: feefeffe feefeffe feefeffe feefeffe
3fff0a20: feefeffe feefeffe feefeffe feefeffe
3fff0a30: feefeffe feefeffe feefeffe feefeffe
3fff0a40: feefeffe feefeffe feefeffe feefeffe
3fff0a50: feefeffe feefeffe feefeffe feefeffe
3fff0a60: feefeffe feefeffe feefeffe feefeffe
3fff0a70: feefeffe feefeffe feefeffe feefeffe
3fff0a80: feefeffe feefeffe feefeffe feefeffe
3fff0a90: feefeffe feefeffe feefeffe feefeffe
3fff0aa0: feefeffe feefeffe feefeffe feefeffe
3fff0ab0: feefeffe feefeffe feefeffe feefeffe
3fff0ac0: feefeffe feefeffe feefeffe feefeffe
3fff0ad0: feefeffe feefeffe feefeffe feefeffe
3fff0ae0: feefeffe feefeffe feefeffe feefeffe
3fff0af0: feefeffe feefeffe feefeffe feefeffe
3fff0b00: feefeffe feefeffe feefeffe feefeffe
3fff0b10: feefeffe feefeffe feefeffe feefeffe
3fff0b20: feefeffe feefeffe feefeffe feefeffe
3fff0b30: feefeffe feefeffe feefeffe feefeffe
3fff0b40: feefeffe feefeffe feefeffe feefeffe
3fff0b50: feefeffe feefeffe feefeffe feefeffe
3fff0b60: feefeffe feefeffe feefeffe feefeffe
3fff0b70: feefeffe feefeffe feefeffe feefeffe
3fff0b80: 3fff202c 3fff20fc 3ffe8867 00000000
3fff0b90: 3fff20ac 0000000f 00000000 3fff20c4
3fff0ba0: 0000000f 00000000 00000000 00000000
3fff0bb0: 000080d4 3ffe9638 00000000 3ffe9638
3fff0bc0: 00000000 3ffe9638 00000000 3ffe9638
3fff0bd0: 00000000 3ffe9638 00000000 3ffe9638
3fff0be0: 00000000 00000000 ffffffff fe000001
3fff0bf0: 3ffe8902 00000000 fe010035 00000000
3fff0c00: 00000000 feefeffe feefeffe feefeffe
3fff0c10: feefeffe feefeffe feefeffe feefeffe
3fff0c20: feefeffe feefeffe feefeffe feefeffe
3fff0c30: feefeffe feefeffe feefeffe feefeffe
3fff0c40: feefeffe feefeffe feefeffe 3ffefc3c
3fff0c50: 3fffdad0 00000000 3ffefc34 4020b898
3fff0c60: feefeffe feefeffe 3ffefc50 40100718
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(1,6)
ets Jan 8 2013,rst cause:4, boot mode:(1,6)
wdt reset
