Dear Costas
I very much appreciate your help, however I am still having no results even with your code.
Is it possible something needs to change in the library to get it to work ? Something specific for NodeMCU ?
I am using Arduino IDE
Is there some debug info I can activate, since I am seeing nothing in my serial monitor except the three values, but no return.
I haven’t finish the discussion because lack of the help from developers. It’s waste of time for me.
Show me how to integrate Webhook widget with Thingspeak.com one of most popular IoT services. There is no response from the widget. That’s why I was asking for help (and still asking) Blynk offeres paid services, so it should be functional.
Hereby the log with the debug on. Sorry it took some time to get this , but here it is
As you can see, the button is pushed when the 3 numbers are showing in the log, but no return from the call
@Jamin which library version are you using and are you using Blynk’s cloud server?
I am still on 0.4.0 and my webhook test was with a local server that is also a few versions behind.
@Robert_Holscher I actually wanted you to try 0.4.0 as that is working for me. I haven’t seen any reports of webhook bugs in the latest library or server so 0.4.3 should be ok.
Please paste as many screenshots of your project as possible and I will check with mine.
