[SOLVED] Virtual pin reads 0 at first run / Slider sends "0" when first run
Slider sets to ex=125, but hardware reads 0 from virtual pin, which is output of slider… when i touch and change to slider, than gets real value of slider… but firstly always read 0 from virtual pin… i want to read slider value when i first run…
i want to refresh virtual values at first run, to read values i have to change values from iphone… thanks
If you use sync it should read last value. Check the docs.
ok, thanks… it runs :slight_smile:
