[SOLVED] Using Bridge function between WeMos D1 R2 ESP and MEGA
Hi Dmitriy
I’m quite sure I’m using auth tokens generated from my local server. I validated it by logging in as Admin on my local Blynk server and ensured both tokens were correctly copied across to the app. I assume the Blynk app would say “WeMos” or “MEGA” offline if there was no communication.
Take out the delay (500)
use simpletimer
like to report I have WeMos talking to MEGA using Bridge and a local Blynk Server. Very powerful feature once you get it going !
It was pretty easy in the end but a little tricky to get going - could do with more examples and documentation :slight_smile:
Hi @mars I want to see your code that is work.
This topic is over a year old. We now have more details and examples in the Documents and Sketch Builder (links at the upper right of this page).
If you have problems with your project, please create your own “Help with my Project” topic and we can assist. Thank you.
