[Solved] Usb connection error
Just wanted to connect my Arduino USB with blynk I now get an error program files
So it stands there with me
The command "Files" is either misspelled or could not be found. Connecting device at COM3 to blynk-cloud.com:8442 ... The command "C: \ Program" is either misspelled or could not be found. Reconnecting in 3s ...
Got the new Blynk version v0.4.3
Can you tell me how I can connect again Arduino UNO R3 with blynk
If you have latest version, you can try “Tools -> Blynk: Run USB script” option
Ok but then comes when I do so Wait 0 seconds. Continue with any key ... The command "com2tcp" is either misspelled or could not be found. Reconnecting in 3s ...
Ok, it’s probable because you put your libraries ad tools in ProgramFiles, instead of sketchbook folder.
Thank you it has made new Arduino folder
Is the problem fixed?
hello
Yes the problem is fixed the whole arduino programs in a completely new folder made
