I do not know if it is the best, but it works:
//#define BLYNK_PRINT Serial // Comment this out to disable prints and save space
#include <Ethernet.h>
#include <SimpleTimer.h> // here is the SimpleTimer library
char auth[] = "xxx"; //insert here your token generated by Blynk
SimpleTimer timer; // allocate a name (timer) to the timer
int relay1 = 7;
int relay2 = 8;
int relay3 = 9;
int button1 = 2;
int button2 = 3;
int button3 = 5;
int relayVButton1 = 0;
int relayVButton2 = 0;
int relayVButton3 = 0;
boolean relayState1 = 1;
boolean relayState2 = 1;
boolean relayState3 = 1;
boolean buttonState1 = 1;
boolean buttonState2 = 1;
boolean buttonState3 = 1;
WidgetLED led1(10); //virtual led
WidgetLED led2(11); //virtual led
WidgetLED led3(12); //virtual led
Blynk.begin(auth); //insert here your SSID and password
timer.setInterval(600L, somefunction);
pinMode(relay1, OUTPUT);
pinMode(button1,INPUT_PULLUP);
pinMode(relay2, OUTPUT);
pinMode(button2,INPUT_PULLUP);
pinMode(relay3, OUTPUT);
pinMode(button3,INPUT_PULLUP);
digitalWrite(relay1, 1);
digitalWrite(relay2, 1);
digitalWrite(relay3, 1);
void somefunction()
buttonState1 = digitalRead (button1);
if (buttonState1 < 1 || relayVButton1 > 0)
relayState1 = !relayState1;
digitalWrite(relay1, relayState1);
buttonState2 = digitalRead (button2);
if (buttonState2 < 1 || relayVButton2 > 0)
relayState2 = !relayState2;
digitalWrite(relay2, relayState2);
buttonState3 = digitalRead (button3);
if (buttonState3 < 1 || relayVButton3 > 0)
relayState3 = !relayState3;
digitalWrite(relay3, relayState3);
if (digitalRead(relay1) == LOW) //virtual led1
led1.on();
led1.off();
if (digitalRead(relay2) == LOW) //virtual led2
led2.on();
led2.off();
if (digitalRead(relay3) == LOW) //virtual led3
led3.on();
led3.off();
BLYNK_WRITE(V4)
relayVButton1 = param.asInt(); // Get the state of the VButton
BLYNK_WRITE(V5)
relayVButton2 = param.asInt(); // Get the state of the VButton
BLYNK_WRITE(V6)
relayVButton3 = param.asInt(); // Get the state of the VButton
timer.run(); // call the simple timer routine
