Here is a BIG hint. Have a play around with ‘exclusive or’. It looks like ‘||’ in the code.
1)Set a Boolean from your physical switch
2)Set another Boolean from your virtual switch
3)XOR (exclusive or) the two Booleans together
4)hey presto… The result is the state you want your output to be in.
It works like a 2 way switch in a house, YAY!
If you want to go further and display the actual state of the output on your dashboard, then read the output state and then write it to a display widget on your dash.
char auth[] = "xxxxx"; //insert here your token generated by Blynk
int relay1 = 12;
int button1 = 13;
int relayVButton = 0;
boolean relayState = 1;
boolean buttonState = 0;
WidgetLED led1(11); //virtual led
Serial.begin(115200); // See the connection status in Serial Monitor
Blynk.begin(auth, "ssid", "password"); //insert here your SSID and password
buttonState = digitalRead (button1);
if (buttonState > 0){
relayState = !relayState;
digitalWrite(relay1, relayState);
delay(500);
pinMode(relay1, OUTPUT);
pinMode(button1,INPUT);
BLYNK_WRITE(V5)
// Get the state of the VButton
relayVButton = param.asInt();
// put your main code here, to run repeatedly:
if (buttonState > 0 || relayVButton > 0){
delay(500);
//----------------button virtual led---------------
byte inp = digitalRead(relay1);
if (inp == HIGH)
led1.on();
led1.off();
Hey @NickMurray and @zeeko why do my code dont my code work with two physical buttons, two ralays and two virtual buttons? do I need a timer to avoid flood? how can I set it up? here is the code with two everything: #define BLYNK_PRINT Serial // Comment this out to disable prints and save space #include <ESP8266WiFi.h> #include <BlynkSimpleEsp8266.h>
int relay1 = 12;
int relay2 = 14;
int button1 = 13;
int button2 = 5;
int relayVButton1 = 0;
int relayVButton2 = 0;
boolean relayState1 = 0;
boolean relayState2 = 0;
boolean buttonState1 = 0;
boolean buttonState2 = 0;
WidgetLED led2(10); //virtual led
buttonState1 = digitalRead (button1);
if (buttonState1 > 0){
relayState1 = !relayState1;
digitalWrite(relay1, relayState1);
delay(500);
buttonState2 = digitalRead (button2);
if (buttonState2 > 0){
relayState2 = !relayState2;
digitalWrite(relay2, relayState2);
delay(500);
pinMode(relay2, OUTPUT);
pinMode(button2,INPUT);
BLYNK_WRITE(V5)
relayVButton1 = param.asInt();
BLYNK_WRITE(V4)
relayVButton2 = param.asInt();
if (buttonState1 > 0 || relayVButton1 > 0){
delay(500);
if (buttonState2 > 0 || relayVButton2 > 0){
delay(500);
//----------------button virtual led1---------------
if (inp == HIGH)
led1.on();
led1.off();
//----------------button virtual led2---------------
byte inp2 = digitalRead(relay2);
if (inp2 == HIGH)
led2.on();
led2.off();
Be careful sending too many requests to the Blynk server, use simpletimer library to help with this. In my code I only check the state of my outputs every 0.2sec
I’m sure there is plenty of stuff on the internet but it is very ‘simple’.
Include the library, name the timer, set the interval, name the function, create the function, call the timer.
SimpleTimer mytimer; // allocate a name (mytimer) to the timer
mytimer.setInterval(1000L, somefunction); // set the interval 1000L is 1s / 1000 ms
// and name your function
mytimer.setInterval(5000L, someotherfunction); // do something every 5 seconds
void somefunction()
// code for whatever you want to do at the chosen intervals (e.g. every 1 second)
void someotherfunction()
// code for whatever you want to do at the chosen intervals (e.g. every 5 seconds)
mytimer.run(); // call the simple timer routine
Please describe the problem and what is happening at your end in more detail. The code compiles ok here. You need to lose the delay(500)'s in the somefunction() as the 2 second timer you have should take care of this. Why do you have the relay state sandwiched between the Blynk.connect() while loop? Does it need to be there?
you have confused @mrebaj with me, @mpo881 . We both have the same color logo and initial. I have not posted any code related to this issue. Thank you though for your help.
