Ok Pete thank you!
So I set this:
Timer V0 >>> Button V1 >>> Relay D1
and I use this example to control all writtend by Costas Ok?:
BLYNK_WRITE(V0){ // Timer widget
if (param.asInt() == 1) {
Blynk.virtualWrite(V1, 1); // button set to ON from timer
Serial.println("Timer ON activated");
else{
Blynk.virtualWrite(V1, 0); // button set to OFF from timer
Serial.println("Timer OFF activated");
Blynk.syncVirtual(V1); // sync virtualWrite 0 / 1 to button widget
How do you propose to make this code control your relay?
You’re not doing any digital writes to set a GPIO pin HIGH or LOW to actuate a relay.
What are you doing a Blynk.syncVirtual in your code snippet?
yes, is inusual, for me it’s also useless.
It is normal that the code I copied is only a part. I have copied only the crucial part of the code, which highlights the change of state of the timer on the Button. It is normal that I have to add this:
BLYNK_WRITE(V1){ // Button widget in SWITCH mode
digitalWrite(WEMOS_ON_BOARD_LED, LOW);
Serial.println("LED ON");
else{
digitalWrite(WEMOS_ON_BOARD_LED, HIGH);
Serial.println("LED OFF");
So is your code working the way you want it to?
I should try.
I’ll let you know. Thanks
I solve all! The problem was relay becuase I set my cable on relay NO-NC wrong.
Thank you
I have another small question please.
At the control of my button (when I press OFF), I add a simple command that send a total value of current producted from my solar panel to a graph. Obviously I send this value at the end of the day. In the future I’ll do by timer:
BLYNK_WRITE(buttonFaretto10W){ //control VIRTUAL buttonFaretto10W V0 >> D4
if(param.asInt()==1){
digitalWrite(relayFaretto10WD4, HIGH); // START RELAY
}else{
digitalWrite(relayFaretto10WD4, LOW); // STOP RELAY
Blynk.virtualWrite(correnteTotaleDayGraph, current_day); // SEND VALUE TO GRAPH correnteTotaleDayGraph on V9
current_day = 0;
I send value on virtual V9 and resest the current day for next day.
Now If I set on graph the value V9 I will not see the value why?
Let me know
Thank you
