What does debug shows?
Debug shows no vw on vpin5 (the timer) when using sync:
[18] Connecting to RobsTV
[2652] Connected to WiFi
[2652] IP: 192.168.1.93
[2652]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.4.8 on Arduino
[5001] Connecting to blynk-cloud.com:8442
[5061] <[02|00|01|00] 5417eefaa3204b3e814d6edde7d9a6fd
[5112] >[00|00|01|00|C8]
[5112] Ready (ping: 50ms).
[5112] <[11|00|02|00]Hver[00]0.4.8[00]h-beat[00]10[00]buff-in[00]1024[00]dev[00]Arduino[00]build[00]Jul 28 2017 13:38:59[00]
[5178] >[00|00|02|00|C8]
[15118] <[06|00|03|00|00]
[15169] >[00|00|03|00|C8]
[15401] >[14]k[FD|00|06]
[15402] >vw[00]2[00]1
[15402] <[10]k[FD|00|00]
[15446] >[14]k[FD|00|06]
[15447] >vw[00]0[00]0
[15448] >[14]k[FD|00|06]
[15448] >vw[00]1[00]0
[15449] >[14]k[FD|00|06]
[15450] >vw[00]2[00]1
[15450] <[10]k[FD|00|00]
[15451] >[14]k[FD|00|01]
[15452] >1
[15454] >[14]k[FD|00|06]
[15456] >vw[00]4[00]0
[15458] >[14]k[FD|00|06]
[15460] >vw[00]3[00]0
[15462] <[14]k[FD|00|06]vw[00]4[00]0
[15506] >[14]k[FD|00|06]
[15507] >vw[00]0[00]0
[15507] >[14]k[FD|00|06]
[15508] >vw[00]1[00]0
[15509] >[14]k[FD|00|06]
[15510] >vw[00]2[00]1
[15510] <[10]k[FD|00|00]
[15511] >[14]k[FD|00|01]
[15512] >1
[15514] >[14]k[FD|00|06]
[15516] >vw[00]4[00]0
[15518] >[14]k[FD|00|06]
[15520] >vw[00]3[00]0
[15522] <[14]k[FD|00|06]vw[00]4[00]0
[15526] >[14]R[BC|00|06]
[15528] >vw[00]2[00]0
[15638] >[14]k[FD|00|06]
[15639] >vw[00]0[00]0
[15640] >[14]k[FD|00|06]
[15640] >vw[00]1[00]0
[15641] >[14]k[FD|00|06]
[15642] >vw[00]2[00]0
[15642] >[14]k[FD|00|01]
[15643] >1
[15644] >[14]k[FD|00|06]
[15646] >vw[00]4[00]0
[15648] >[14]k[FD|00|06]
[15650] >vw[00]3[00]0
[15652] <[14]k[FD|00|06]vw[00]4[00]0
[25652] <[06|00|04|00|00]
[25716] >[00|00|04|00|C8]
[35653] <[06|00|05|00|00]
[35716] >[00|00|05|00|C8]
This is the code Iāve got setup for the test:
#define BLYNK_DEBUG
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "xx";
char ssid[] = "xx";
char pass[] = "xx";
WidgetLED testLED(V4);
BLYNK_WRITE(V2) //sync
int pinValue = param.asInt();
if (pinValue == 1)
Blynk.syncAll();
BLYNK_WRITE(V3) //LED toggle
if (pinValue == 1)
testLED.on();
if (pinValue == 0)
testLED.off();
BLYNK_WRITE(V5) //timer
if (pinValue == 1)
testLED.on();
Blynk.virtualWrite(V3, 1);
if (pinValue == 0)
testLED.off();
Blynk.virtualWrite(V3, 0);
When changing from Blynk.syncAll() to Blynk.syncVirtual(V5) it spits out this in the debug:
[204945] >[14],[F5|00|06]
[204946] >vw[00]2[00]1
[204946] <[10],[F5|00|04]vr[00]5
[205006] >[14],[F5|00|01]
[205006] >1
[205054] >[14|0D]@[00|06]
[205055] >vw[00]2[00]0
Which is interesting. I assume vr[00]5 means it is reading the vpin and it knows itās a 1, how do I capitalize on that to make my BLYNK_WRITE(V5) trigger?
Since this thread is really not about the timer failing to trigger anymore, and more about using Blynk.sync() functions with the timer, should I make a new thread? Iād really love to get this resolved.
No, changing to another topic will not improve anyones ability to assist or suggest. I think your topic and issue still is valid and needs resolution⦠it is just determining the cause of such issue, before any resolution can be determined.
E.gā¦
Is it the Timer Widget and how it links with the server (and thus to your device).
Or is the issue is caused by code and/or the way you use sketch timers (not to be confused with the Timer Widget) vs BlynkTimer:
And how/if Blynk.sync() even affects the issue, or does it just add to the confusion.
As is the case with all āNeed Help With My Projectā topics, much of the load is on your own diagnostic and reporting. Until then we are only seeing āsnapshotsā and postulating ideas. So, on that note, do you have any other simpler sketches that can duplicate the issue?
Thatās why I asked if I should make a new topic, I duplicated the issue with the simple sketch 2 posts above this with debug info.
I think I figured out why the timer was missing triggers in the first place: I had a webhook assigned to one of my pins that was generating a packet too big error when it returned a json and causing the next ~8 commands to be skipped. I increased #define BLYNK_MAX_READBYTES to 4092.
@Dmytro need to think how to handle this - maybe sync can be disabled for wevhook widget? whatās the use case?
Keeping these possibly related issues in the one topic makes for easier referencing and locating any resolution for future readers.
I was actually referring to the original issue of missed timers, not the potential sync contribution⦠but you seem to have resolved that timer issue already. Good diagnostics! ![]()
This topic is marked SOLVED, however feel free to keep adding any new related issues with regards to sync, timers, etc.
But this is feature
. If we disable this someone else will create topic saying why I canāt get data from webhook :).
Letās leave as it is for now. Iāll just add additional warnings to docs for now. If more people will complain we will thinks further.
