Hey!
I am after some help if anyone can. I have a NodeMCU board I am using to learn some basics. I have currently got everything set up with a rain detector, so it reads the A0 pin and sends the data to Blynk. I also have it trigger an event (notification) if the current value drops x amount below the previously measured value.
I would now like to implement the use of the Numeric Input in the Blynk App. Which I have managed to get set up and connected to my NodeMCU to read and write the value as it changes. However, this value does not seem to be used as part of my code, when called up in the if (sensorValue < oldValue - threshold)
line.
Am I missing something basic here? I have tried a few things to no avail. Thank you in advance!
#define BLYNK_TEMPLATE_ID "XXXXX"
#define BLYNK_DEVICE_NAME "XXXX"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_SPARKFUN_BLYNK_BOARD
#define USE_NODE_MCU_BOARD
//#define USE_WITTY_CLOUD_BOARD
#include "BlynkEdgent.h"
int oldValue; //assigning oldValue as an integer.
int threshold; //assigning threshold as an integer.
BlynkTimer testing; //creating a BlynkTimer called testing.
void myTimerEvent()
int sensorValue = analogRead(A0);
Blynk.virtualWrite(V5, sensorValue);
Blynk.logEvent("wet_detected");
oldValue = sensorValue;
delay(100);
BlynkEdgent.begin();
testing.setInterval(1000L, myTimerEvent);
// This function will be called every time the Wetness Threshold
// in Blynk app writes values to the Virtual Pin 1
BLYNK_WRITE(V1)
int threshold = param.asInt(); // assigning incoming value from pin V1 to a variable (threshold).
Serial.println(threshold);
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
// Serial.print("V1 Slider value is: "); (example)
// Serial.println(pinValue); (example)
BlynkEdgent.run();
testing.run(); // Initiates BlynkTimer
