[SOLVED] Sync physical button to other ESP's
Can you help me to edit my sketch ?
//#define BLYNK_PRINT Serial // Defines the object that is used for printing
//#define BLYNK_DEBUG        // Optional, this enables more detailed prints
#define VPIN V2
char auth[] = "xxxx"; //blynk auth token
char ssid[] = "xxxx";
char pass[] = "xxxx";
void lightOn();
void lightOff();
boolean LampState = 0;
boolean SwitchReset = true;
const int TacSwitch = D5;
const int RelayPin = D6;
WidgetLED VLED(V12);
  pinMode(RelayPin, OUTPUT);
  pinMode(TacSwitch, INPUT_PULLUP);
  digitalWrite(RelayPin, LOW);
  timer.setInterval(100, ButtonCheck);
void ButtonCheck() {
  boolean SwitchState = (digitalRead(TacSwitch));
  if (!SwitchState && SwitchReset == true) {
    if (LampState) {
      lightOff();
      lightOn();
    SwitchReset = false;
    delay(50);
  else if (SwitchState) {
    SwitchReset = true;
void ToggleRelay() {
  LampState = !LampState;
  if (LampState) {
       lightOn();
  else lightOff();
void lightOn() {
    LampState = 1;
    Blynk.virtualWrite(VPIN, HIGH);
    VLED.off();
void lightOff() {
    digitalWrite(RelayPin, HIGH);
    LampState = 0;
    Blynk.virtualWrite(VPIN, LOW);
    VLED.on();
BLYNK_WRITE(VPIN) {
  int SwitchStatus = param.asInt();
    if (SwitchStatus == 2){
    ToggleRelay();
  else if (SwitchStatus){
    lightOn();
  else lightOff();
