[SOLVED] Sync example generates error
Hello
When compiling the “Sync” example I get the error:
" error: ISO C++ forbids declaration of ‘BLYNK_CONNECTED’ with no type [-fpermissive]"
I then tried to run Blync.syncAll() directly in the setup routine. I get the error:
error: ‘class BlynkEthernet’ has no member named ‘syncAll’
I am using library v.0.3.1 with IDE v 1.6.5
What am I missing?
Thank you
Julia
Hello, you need to take latest library from trunk - “Download ZIP” button. Also this feature works only with local servers at the moment.
Is this still only applicable for local servers? I’m having the same error presented to me.
@joshblease it works on any server. Probably you have outdated library version?
