[SOLVED] Sparkcore "your particle core is not in network"
Hello, I have a Spark core, I had tried to make a app with blynk, I just had been trying to turn on/off a led, but it’s doesn’t work, in particle build I put the next code:
#include "blynk/blynk.h"
char auth[] = "xxxxxxx";
  delay(5000);
  Blynk.begin(auth);
“xxxx” auth code, in the app Blynk say me, “your particle core is not in network” But my core are in my network, because I programming on cloud api.
this code I saw in http://www.sitepoint.com/how-to-make-an-effective-iot-dashboard-without-coding/
Thank You
Have you tried this instructions:
http://docs.blynk.cc/#hardware-set-ups-particle-formely-spark
Yes, I followed the steps, but do not work. My board is sparkcore v1
can you connect to serial using cli and post the output here. Thanks
