[SOLVED] Shared access (Android)
Hello, I’ve been waiting for the next update and it came out but there is still a problem with my project. When I try to share it with others it says the owner has removed sharing even though on my phone it’s saying that shared access is on.
Can you try making an empty new project and share that? Maybe you need a new auth token or something.
Are you starting your shared project? Shared projects are enabled on the “client” side only when they are active. In case of inactive - ‘client’ will show a notice about stopped project.
@BlynkAndroidDev, no I was not. Seems to be working now. Sorry for the delay, and thanks for letting me know :slight_smile:
