Installed Java module using Diskstation´s Package Center
Created a blynk folder using Diskstation’s File Station
Downloaded latest Blynk server (server-0.29.5-java8.jar) and stored it into the blynk folder
Via PuTTY, ran the cmd: sudo java -jar /volume1/blynk/server-0.29.5-java8.jar -dataFolder /volume1/blynk/
From which I got the following response:
“Blynk Server 0.29.6-SNAPSHOT successfully started. All server output is stored in folder ‘/logs’ file. Your Admin login email is admin@blynk.cc Your Admin password is admin”
In Diskstation Firewall opened ports 8441, 8442 and 8443 and associated them to ALL protocols as destination.
@Xandr Your suggestion to modify crontab to auto start Blynk server did not work in my case. Is there a way to test the crontab file? I’m not too keen in Linux
Did you change path to your Blynk server? Also check path to java. Did you see some errors when run watchdog.sh? And be careful, sudo doesn’t work in cron/scripts when you don’t use sudo without password.
I see in your script server=“server-0.29.6.jar” for you it should be server=“server-0.29.5-java8.jar” and if you don’t use config file for your server delete -serverConfig /volume1/blynk/server.properties.
