[SOLVED] Servo does not work with this code
when i use this code with the ultrasonic sensors , there is no feedback from the servos. I used a mg995 servo and two HC-SR04 ultrasonic sensors .Servo works with the servo example blynk skectch.
#include <Ethernet.h>
#include <Servo.h>
char auth[] = "my auth";
Servo servo;
#define echoPin 8 // Echo Pin
#define trigPin 9
#define echoPin1 7
#define trigPin1 6// Trigger Pin
long duration, distance, d, dp;
long duration1, distance2, d1, dp1; // Duration used to calculate distance
  Blynk.begin(auth);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(trigPin1, OUTPUT);
  pinMode(echoPin1, INPUT);
  pinMode(3, OUTPUT);
  servo.attach(5);
  /* The following trigPin/echoPin cycle is used to determine the
    distance of the nearest object by bouncing soundwaves off of it. */
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin1, LOW);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  digitalWrite(trigPin1, HIGH);
  duration1 = pulseIn(echoPin1, HIGH);
  //Calculate the distance (in cm) based on the speed of sound.
  distance = duration / 58.2;
  d = 35 - distance;
  dp = 2.86 * d;
  distance2 = duration1 / 58.2;
  d1 = 35 - distance2;
  dp1 = 2.86 * d1;
  Serial.println(dp);
  Serial.println(dp1);
  delay(500);
BLYNK_READ(V8)
  Blynk.virtualWrite(8, dp);
BLYNK_READ(V9)
  Blynk.virtualWrite(9, dp1);
BLYNK_WRITE(V3)
  servo.write(param.asInt());
Try to remove the delay(500) and use the SimpleTimer instead.
Thanks , But how to include the simple timer ,Im new to coding with this library .
Please look at the Blynk PushData example. It has an example of how to use the library :slight_smile:
Thanks got it working
:slight_smile:
Also please don’t use pulseIn as it is bad blocking way of using HC-SR04 (not your fault since all “tutorials” show this unfortunately) use interrupts instead, it will also make Blynk working smoother.
