(SOLVED) Server not responding on local ip
I have configurated all parameters and i have two problems:
1 server responding only on 127.0.0.1:9443/admin
2 the blynk app don’t connect to server 192.168.1.9:8443
This is the server log:
2017-03-31 19:57:31.994 WARN - Problem resolving current host IP.
2017-03-31 19:57:32.000 INFO - Using data dir ‘h:\blink\data’
2017-03-31 19:57:32.473 INFO - Region : local
2017-03-31 19:57:33.142 INFO - Initializing gmail smtp mail transport. Username : dinosauroxxxxxx@gmail.com. SMTP host : smtp.gmail.com:587
2017-03-31 19:57:33.742 WARN - Found server certificates but no client certificate for ‘H:\Blink’ path. Using one way ssl.
2017-03-31 19:57:33.830 WARN - Problem resolving current host IP.
2017-03-31 19:57:33.949 WARN - Problem resolving current host IP.
2017-03-31 19:57:34.198 INFO - Hardware plain tcp/ip server listening at 8442 port.
2017-03-31 19:57:34.203 INFO - Hardware SSL server listening at 8441 port.
2017-03-31 19:57:34.207 INFO - Application server listening at 8443 port.
2017-03-31 19:57:34.211 INFO - HTTP API and WebSockets server listening at 8080 port.
2017-03-31 19:57:34.215 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
2017-03-31 19:57:34.219 INFO - Mqtt hardware server listening at 8440 port.
For the first issue i have modified this server properties:
allowed.administrator.ips=0.0.0.0/0
For the second issue the server don’t work via wifi but only via ethernet cable… (i have read other post that explain this problem)
Blink app now connecting very well :heart_eyes:
