[SOLVED] Server-0.17.2.jar Local Server Error Messages
Newly installed server-0.17.2.jar throws some error messages…
java -jar server-0.17.2.jar -dataFolder ~/Blynk
2016-09-03 14:28:56,639 main ERROR File contains an invalid element or attribute “filePattern”
2016-09-03 14:28:56,684 main ERROR appender File has no parameter that matches element Policies
Blynk Server successfully started.
All server output is stored in folder ‘/root/Blynk/./logs’ file.
…previous installed version server-0.16.0.jar doesn’t mention.
java -jar server-0.16.0.jar -dataFolder ~/Blynk
Are new parameters required on the server.properties file?
Mine contains
cat Blynk/server.properties
data.folder=~/Blynk
http.port=8181
administration.https.port=7443
allowed.administrator.ips=0.0.0.0/0
Thank you and best regards,
Blynk are aware of the warnings but it doesn’t appear to stop the server running.
Yes. It is fixed. For now you may ignore it. It has no affect.
@Avenue33 I just updated build. Please download file again.
