[SOLVED] Sending data to slider
Hi. I am currently building a fish tank LED light system using an Arduino Mega and Blynk. I have 4 channels off lights (White, Blue, Red and Green for example).
I then have three light modes… lunar, low sun and midsun.
I have separated these light modes using a menu and upon calling each relevant menu, it is SUPPOSED to load each of the channels data to the sliders so that I can adjust if necessary. I then have a save button which will save whatever adjustment I have made.
The problem is, as I move through the different light modes, the previously saved data does not reappear on the slider. For example if I set ch1 on Lunar to 150, if I saved it and then moved to Lowsun menu, and then back to Lunar… I would expect the slider to jump back to 150, but it goes to 0.
Is there a way that I can get it to do this for each of the channels across each of the light modes?
I am very very new to Arduino and Blynk and have limited knowledge of C++ so please be gently.
Here is just a rough copy of code that i have been playing with to learn how to make it work before starting the main sketch.
char auth[] = "*****HIDDEN*****";
int savechanges;  // used to adjust light levels
int lightedit;    // as above
SoftwareSerial SerialBLE(10, 11); // RX, TX
struct LEDS // for storing light intensity values
  float ch1;
  float ch2;
  float ch3;
  float ch4;
typedef struct LEDS LightColor;
LightColor lunar = {             // Lunar colours
  0,0,0,0};
LightColor lowsun = {            // Lowsun colours
  0,0,0,0};
LightColor midsun = {            // Midsun colours
  0,0,0,0};
LightColor highsun = {           // Highsun colours
  0,0,0,0};
LightColor edit = {              // Used to edit colours
  0,0,0,0};
BLYNK_WRITE(V1)
  switch (param.asInt())
    case 1: // Item 1
      lightedit=1;    // 0-NOT EDITING  1-EDIT LUNAR  2-EDIT LOWSUN  3-EDIT MIDSUN
      Serial.println("Lunar Selected");
      Serial.print("lightedit=");
      Serial.println(lightedit);
      edit.ch1=lunar.ch1;
      edit.ch2=lunar.ch2;
      edit.ch3=lunar.ch3;
      edit.ch4=lunar.ch4;
      Blynk.virtualWrite(V2, lunar.ch1);
      Blynk.virtualWrite(V3, lunar.ch2);
      Blynk.virtualWrite(V4, lunar.ch3);
      if (savechanges==1)
        Serial.println("SAVED???");
        lunar.ch1=edit.ch1;
        lunar.ch2=edit.ch2;
        lunar.ch3=edit.ch3;
        lunar.ch4=edit.ch4;
        printall();
      break;
    case 2: // Item 2
      lightedit=2;    // 0-NOT EDITING  1-EDIT LUNAR  2-EDIT LOWSUN  3-EDIT MIDSUN
      Serial.println("Low Sun selected");
      edit.ch1=lowsun.ch1;
      edit.ch2=lowsun.ch2;
      edit.ch3=lowsun.ch3;
      edit.ch4=lowsun.ch4;
      Blynk.virtualWrite(V2, lowsun.ch1);
      Blynk.virtualWrite(V3, lowsun.ch2);
      Blynk.virtualWrite(V4, lowsun.ch3);
      if (savechanges==1)
        lowsun.ch1=edit.ch1;
        lowsun.ch2=edit.ch2;
        lowsun.ch3=edit.ch3;
        lowsun.ch4=edit.ch4;
        printall();
      break;
    case 3: // Item 3
      lightedit=3;    // 0-NOT EDITING  1-EDIT LUNAR  2-EDIT LOWSUN  3-EDIT MIDSUN
      Serial.println("Mid Sun selected");
      edit.ch1=midsun.ch1;
      edit.ch2=midsun.ch2;
      edit.ch3=midsun.ch3;
      edit.ch4=midsun.ch4;
      Blynk.virtualWrite(V2, midsun.ch1);
      Blynk.virtualWrite(V3, midsun.ch2);
      Blynk.virtualWrite(V4, midsun.ch3);
      if (savechanges==1)
        midsun.ch1=edit.ch1;
        midsun.ch2=edit.ch2;
        midsun.ch3=edit.ch3;
        midsun.ch4=edit.ch4;
        printall();
      break;
    default:
      Serial.println("Unknown item selected");
BLYNK_WRITE(V2)
  edit.ch1 = param.asInt(); // assigning incoming value from pin V2 to a variable
  Serial.print("V2 Slider value is: ");
  Serial.println(edit.ch1);
BLYNK_WRITE(V3)
  edit.ch2 = param.asInt(); // assigning incoming value from pin V2 to a variable
  Serial.print("V3 Slider value is: ");
  Serial.println(edit.ch2);
BLYNK_WRITE(V4)
  edit.ch3 = param.asInt(); // assigning incoming value from pin V2 to a variable
  Serial.print("V4 Slider value is: ");
  Serial.println(edit.ch3);
BLYNK_WRITE(V10)
  int savechanges = param.asInt(); // assigning incoming value from pin V10 to a variable
  savevalues();
BLYNK_WRITE(V11)
  int printa = param.asInt();
  if (printa==1)
    printall();
  SerialBLE.begin(9600);
  Blynk.begin(SerialBLE, auth);
void savevalues()
  if (lightedit==1)    // 0-NOT EDITING  1-EDIT LUNAR  2-EDIT LOWSUN  3-EDIT MIDSUN
    lunar.ch1=edit.ch1;
    lunar.ch2=edit.ch2;
    lunar.ch3=edit.ch3;
    lunar.ch4=edit.ch4;
    Serial.println("SAVE VALUES 1");
    printall();
  else if (lightedit==2)
    Serial.println("SAVE VALUES 2");
    printall();
  else if (lightedit==3)
    Serial.println("SAVE VALUES 3");
    printall();
void printall()
  Serial.println("=============================================");
  Serial.print("LUNAR EDIT: ");Serial.print(edit.ch1);Serial.print(" - ");Serial.print(edit.ch2);Serial.print(" - ");Serial.println(edit.ch3);
  Serial.print("LUNAR REAL: ");Serial.print(lunar.ch1);Serial.print(" - ");Serial.print(lunar.ch2);Serial.print(" - ");Serial.println(lunar.ch3);
  Serial.print("LOWSUN EDIT: ");Serial.print(edit.ch1);Serial.print(" - ");Serial.print(edit.ch2);Serial.print(" - ");Serial.println(edit.ch3);
  Serial.print("LOWSUN REAL: ");Serial.print(lowsun.ch1);Serial.print(" - ");Serial.print(lowsun.ch2);Serial.print(" - ");Serial.println(lowsun.ch3);
  Serial.print("MIDSUN EDIT: ");Serial.print(edit.ch1);Serial.print(" - ");Serial.print(edit.ch2);Serial.print(" - ");Serial.println(edit.ch3);
  Serial.print("MIDSUN REAL: ");Serial.print(midsun.ch1);Serial.print(" - ");Serial.print(midsun.ch2);Serial.print(" - ");Serial.println(midsun.ch3);
This is probably why your slider is resetting to 0. Slider takes int not float.
You are fantastic!!! I was trying different things for hours last night and couldn’t work it out. Just tried it and works perfectly! Thanks.!!
