[solved - reassigned V pins] MKR1000 menu widget compiling problems
I built a project 2 weeks back with an Arduino MKR1000 (started 9th March, last update was the 15th), and uncovered it again today to test, but the code now won’t compile. There’s a problem with virtual pin 4, which is connected to a menu widget; I assume a new update changes how they work, but I can’t see how from the documentation (online and in the app). Blynk library version 0.4.6 is installed.
Is this something I can fix in the code or should I do something like reinstall the library?
Error feedback is:
D:\Documents\Arduino\Mar9_BlynkFinalProject\Mar9_BlynkFinalProject.ino: In function 'void BlynkWidgetWrite4(BlynkReq&, const BlynkParam&)':
D:\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkHandlers.h:155:10: error: redefinition of 'void BlynkWidgetWrite4(BlynkReq&, const BlynkParam&)'
     void BlynkWidgetWrite ## pin (BlynkReq BLYNK_UNUSED &request, const BlynkParam BLYNK_UNUSED &param)
D:\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkHandlers.h:163:31: note: in expansion of macro 'BLYNK_WRITE_2'
 #define BLYNK_WRITE(pin)      BLYNK_WRITE_2(pin)
D:\Documents\Arduino\Mar9_BlynkFinalProject\Mar9_BlynkFinalProject.ino:236:1: note: in expansion of macro 'BLYNK_WRITE'
 BLYNK_WRITE(V4)
D:\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkHandlers.h:155:10: error: 'void BlynkWidgetWrite4(BlynkReq&, const BlynkParam&)' previously defined here
D:\Documents\Arduino\Mar9_BlynkFinalProject\Mar9_BlynkFinalProject.ino:186:1: note: in expansion of macro 'BLYNK_WRITE'
The menu code seems right, from the documentation
BLYNK_WRITE(V4)
  switch (param.asInt())
    case 1:
     Serial.println("System is now off.");
     //logic 1
     break;
    case 2:
     Serial.println("Eco mode selected");
     //logic 2
     break;
    case 3:
     Serial.println("Fast mode selected");
     //logic 3
     break;
    case 4:
     Serial.println("Custom mode selected. Slider can now be moved");
     //logic 4
     break;
Thank you in advance!
I sometimes find these errors misleading… Can you post the whole code so I (or someone else) can try to compile it and compare errors. Thanks
Most probably you assigned several Write handlers for the same V4 pin
Ah. Sorry, stupid mistake - I’d assigned V4 to both a menu and a step widget. Thank you @vshymanskyy, good pointer :flushed:
