Hi friends. is it possible to read analog data from GPIO on nodemcu? is there any example ?
thanks
the esp8266 has one single analog pin.
you can read it directly anytime with the AnalogRead(); command.
https://www.arduino.cc/en/Reference/AnalogRead
or, if you need to read directly from app, just create a display widget and select the analog pin, instead of virtual. thats all.
No. I need read multiple device analog ( MQ sensors ) in one nodemcu
not possible.
you will need a different mcu with more analog pins, or an analog demux
http://www.futureelectronics.com/en/analog/multiplexer-demultiplexer.aspx
thanks for reply. can I use arduino pro micro with esp8266 shield ? the arduino micro pro has 4 analog pin
yes, that should work. or you can try the updated version of arduino nano by robodyn, the black ones. find on ali.
Nano V3 ATmega328/CH340G, Micro USB, Pin headers NOT soldered. Compatible for Arduino Nano V3.0
http://s.aliexpress.com/RzQjER7b
(from AliExpress Android)
thanks you helped me
i updated post, please check it
thanks. I bought arduino pro micro + esp01 and build my own wifi shield. all analog pins worked perfectly
Keep in mind now, you are using the OLD arduino as the main processor and the ESP “only” as Wi-Fi adapter…
This duo will work for sure but… The ESP8266 is more powerful than the Arduino, if I were you, I would consider the use of the ESP as the main processor.
Regards
+1 … and if you need more ADC… then its only $2 away.
Oh… I didn’t realise that… what a silly design decision
You will soon
