hello,
I follow instructions and the IOT work well. now I try to reconnect the hardware each time my pi restart.
I modify my rc.local and the last line for connecting the hardware don’t execute correctly.
have you some idea for write correctly the line ?
node /home/pi/python/index8081.js ‘ef7a57a02ed4447ab2816e360e7f0ddd’ &
Thanks.
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# start serveur blynk
java -jar /home/pi/serveur/server-0.41.2-java8.jar -dataFolder /home/pi/serveur/data -serverConfig /home/pi/serveur/server.properties -mailConfig /home/pi/serveur/mail.properties &
# start dyndns for static IP from internet
/usr/local/bin/noip2 &
# automatic start hardware compatible with blynk application
node /home/pi/python/index8081.js 'ef7a57a02ed4447ab2816e360e7f0ddd' &
exit 0
regards,
Joel
